running hot
Old Mar 23, 2007 | 03:58 PM
joshb's Avatar
joshb
Default running hot
I am new to the dodge world. I just picked up a 99 ram yesterday. This morning while driving to the airport, I noticed the temp guage was almost in the red. I checked the coolant reservoir and it was full. All of the hoses are tight and are not swelling anywhere. Supposedly the dealer just had the radiator flushed and a new thermostat put in. What could be the problem?
Old Mar 23, 2007 | 04:12 PM
2001mustang_gt's Avatar
2001mustang_gt
Default RE: running hot
thermostat could be in the wrong way...or could be a junk thermostat...or something in the water pump or in the system itself
Old Mar 23, 2007 | 10:33 PM
joshb's Avatar
joshb
should I flush it first to see if that fixes the problem?
Old Mar 23, 2007 | 10:48 PM
shott8283's Avatar
shott8283
you should doa complete fluid change and tune up to get a good baseline to start from to help aid in timely routine and preventative maintence.
coolant flush with a new t-stat would help.. possibly waterpump
if you JUST bought it.. i would be all up and down that dealers *** about it..
Old Mar 24, 2007 | 02:08 AM
Chopper1's Avatar
Chopper1
You say the reservoir is full. How about the radiator. The cap pressure allows the fluid to get sucked back to the radiator and vise versa. If the cap or hose to the tank is weak/bad it will not function right. Just remember, only open when cool or while running....
Either way the dealer should correct.........
Old Mar 24, 2007 | 12:16 PM
joshb's Avatar
joshb
I just opened the radiator and let the truck run for 30 mins. Some air bubbles came out but the coolant never dropped so that means that the thermostat is sticking right?
Old Mar 24, 2007 | 12:28 PM
dhvaughan's Avatar
dhvaughan
test thermostat like this.
when the thermostat opens you will get hot water flowing through the top radiator hose and it will get too hot to hold. when your engine temperature gauge comes up to about normal (180-195), if the top rad hose is not getting hot, then the thermostat is not opening. its a good idea to set your heater to ON, temp to hottest setting, doesn't matter about fan. this will allow flow through heater core and help to remove any air pockets.
Old Mar 24, 2007 | 02:57 PM
joshb's Avatar
joshb
ORIGINAL: dhvaughan
last night while it was running, I had the defrost on at full blaston the hottest setting. Once it warmed up to normal temp, the upper radiator hose was really hot. So I guess the thermostat is opening. The coolant level in the radiator didn't change at all. maybe its the water pump?
