Largest Tire Size
Old Mar 27, 2007 | 02:03 AM
dodge5.9liter's Avatar
dodge5.9liter
Default Largest Tire Size
what will be the largest tire size stock form on a 4x4 1997 dodge?
will it fit 33's under or should i stay with 31's??
im thinking about pro-comp mud terrains or mtz mickey thompsons
also what is a nice exhaust that has a nice tone to it?
Old Mar 27, 2007 | 03:36 AM
Cereal Killer's Avatar
Cereal Killer
Default RE: Largest Tire Size
245/75-16Stock
265/75-16What I have
285/75-16Is the biggest that will fit on the stock 16" wheels
Old Mar 27, 2007 | 03:38 AM
Cereal Killer
I'm about to put 285s on mine (33") on mine. I don't anticiptate it to rub at all.
Old Mar 28, 2007 | 09:47 PM
TMS Bill's Avatar
TMS Bill
4x4's came from the dealer with 265/75/16's.
Old Mar 28, 2007 | 09:59 PM
jmhai's Avatar
jmhai
That is what I have (265/75/16's) but they are for a SUV (was on the truck when I bought it) and max PSI is 35 and I don't expect them to last long... When I buy new I plan on sticking with that size but going to a C, D, or E rated tire...What do you recommend..C,D,or E????????
Old Mar 28, 2007 | 10:02 PM
94ram4x4 5.9's Avatar
94ram4x4 5.9
I had 285s for years and they rub on the inside when you turn the wheel full lock, other than that they do great!
Old Mar 28, 2007 | 10:23 PM
mcss8541's Avatar
mcss8541
If you go to www.4wheelparts.com they have a tire/wheel/gear guide that will help and their tech dept is pretty savvy on the subject. As far as exhaust it depends on what you want to spend and what type of performance you want. On my 98 5.9LI'm going with a set of JBA stainless steel headers, dual exhaust 2.5" to a set of 3" Flowmaster Super 40's ( don't need or want cats; however I keep hearing about these magna flow highflow ones)out to each rear corner's at a 45 degree angle. Total cost including shipping $720.
Old Mar 28, 2007 | 10:27 PM
dodge5.9liter
THANKS FOR THE INFO GUYS.
CAN YOU GUYS GIVE ME A CHOICE FOR SOME EXHAUST THAT WILL SOUND GOOD??
WHAT ABOUT CHERRY BOMB?
ARE THEY WORTH IT OR SHOULD I GO WITH A FLOWMASTER OR GIBSONS OR MAGNAFLOW?
WHAT WILL SOUND THE BEST? I WOULDNT MINE NO NOISE! SOUND IS GOOD
Old Mar 28, 2007 | 10:38 PM
mcss8541's Avatar
mcss8541
I you want it load inside the cab and out then go with the Cherry Bomb or the old school Flowmaster, if you want it load outside with a slight rumble inside the cab then go with the Delta Flow design Flowmaster's.
Old Mar 28, 2007 | 10:51 PM
dodge5.9liter
WHAT WILL BE THE BEST BANG FOR THE BUCK?? I DONT WANT IT TO LOUD IN THE INSIDE CAB.
