control arm help
Old Jan 25, 2012 | 12:20 AM
offroadjosh's Avatar
offroadjosh
Default control arm help
Adding another2-3in of lift to my truck(3in now) i have an adj track bar and built my own sway bar drop bracket. looking at building my own control arms to go with the added lift. Any ideas how much longer or shorter they need to be?
Old Jan 25, 2012 | 12:31 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Depends if you are going to use the stock control arm brackets on the frame. If you are, then increase the length such that the axle is centered in the wheel well. Use plumb lines.
Old Jan 25, 2012 | 01:00 AM
offroadjosh
knew, i shouldnt have bought a welder... =p glad i am getting that ford v10(dont gotta worry about breaking my DD) yea i am using original brackets, figure on using round tubing and some Heim joints?
Old Jan 25, 2012 | 01:09 AM
mstephen89's Avatar
mstephen89
you should make long arms, you would be much happier.
Old Jan 25, 2012 | 01:18 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I'm pilfering this info b/c I'll be doing this myself. I'd say hell no to heim joints. They won't last, especially considering your abuse.
Johnny Joints from Currie Enterprises:
step 1. order parts.
step 2. cut pipe to length.
step 3. insert bungs
step 4. weld bungs
step 5. insert bushings/instal joints and bushings into sleeves or whatever part you ordered.
step 6. adjust for caster/camber. .
Approximate reference lengths --
3" Lift - 1/2" Longer than stock.
6" Lift - 1" Longer than stock.
Old Jan 25, 2012 | 11:42 AM
offroadjosh
Sweet thanks! are you saying i am abusive?=P What wheels are those btw? Love them!!
Old Jan 25, 2012 | 12:12 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Your truck told me so.
Helo Maxx 6
But they'll be going away for 8-lug big brothers due to project later this year.
Old Jan 25, 2012 | 01:00 PM
mstephen89's Avatar
mstephen89
you mean 10 lug right whitenuckle? lol, did that guy respond with the 10 lug dana 80 rear?
Old Jan 25, 2012 | 05:29 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Lolz! Yes he did. We've talked over PMs. We'll see in a couple months if its still around when I drive through there.
Old Jan 25, 2012 | 05:33 PM
offroadjosh
10 lug? wow... going to do 8 lug convert?
