Old Aug 4, 2015, 08:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Rim and Tire Setup
Old Feb 3, 2012 | 11:11 PM
  #21
Altair's Avatar
Altair
Dak attack!
Rim size (diameter/width/offset): 20x8.5 +25mm
Rim manufacturer: Boss 335
Tire size: 265/50R-20
Tire manufacturer: Hankook Ventus ST RH06
Lowered (specs): 2" rear lowering shackles
Rubbing (yes/no/trim): No
(Ignore the rusty front brake rotors, whenever they need replacing I'll look for some with a better coating on the non-contact areas)
Old Apr 6, 2012 | 11:18 PM
  #22
RIFF-RAFF's Avatar
RIFF-RAFF
Rim size (diameter/width/offset): 20 x 9
Rim manufacturer: factory Ram 1500 Sport
Tire size: 295/45/20
Lifted (specs): No
Lowered (specs): No
Rubbing (yes/no/trim):No trimming or rubbing
Old Apr 7, 2012 | 02:50 PM
  #23
FrenicX's Avatar
FrenicX
Lifted (specs): No
Lowered (specs): No
now thats the tire size i will go with next time, they look great
Old Apr 7, 2012 | 11:04 PM
  #24
RIFF-RAFF's Avatar
RIFF-RAFF
Hankook recommends a 9.5- 10.5" rim for these tires but I find they fit perfect on the 9" rim. The stock tire size for my truck was 265/60/18 with a 30.4" diameter and these Hankooks are the same diameter but have a 1.9" wider section width.
Old Apr 7, 2012 | 11:46 PM
  #25
FrenicX's Avatar
FrenicX
And still no rubbing? That's nice. Yea that size will definitely my next set. If I can find hancooks by then... they were my first choice and not available in my size at the time.
Old Apr 8, 2012 | 09:37 AM
  #26
RIFF-RAFF's Avatar
RIFF-RAFF
I was really surprised they fit without rubbing, I thought for sure I was going to have to add a leveling kit in the front. Instead, i might drop the rear.
The Hankooks were never on my radar as a tire choice within all the tires available in this size but after reading all the reviews,the Hankooks had far more positives. My buddy that mounted them said he was surprised how little runout there was while spinning on his machine and how little weight they needed to balance for such a big tire. They're very smooth....I like 'em.
Old Apr 9, 2012 | 05:02 PM
  #27
donkeypunch's Avatar
donkeypunch
King Jackass
285/75/16 Goodyear Duratracs (33")
16x7 OEM ST wheels
2" leveling kit
Quite a bit of trimmingmanship in the front, nothing in the rear.
Old Apr 10, 2012 | 09:26 PM
  #28
FrenicX's Avatar
FrenicX
16x7 OEM ST wheels
2" leveling kit
You wouldn't mind snapping a pic of the trimming you did would you? I have a rub that I cannot seem to track down... after trimming a bit.
Old Apr 11, 2012 | 08:23 AM
  #29
dakota_raven's Avatar
dakota_raven
Hey donkey!! You truck will look awsome with my truck's TRX wheels!!
Old Aug 14, 2012 | 07:53 PM
  #30
DakBoi20"'s Avatar
DakBoi20"
Beautiful truck! Here's mine on Ram 1500 rims painted with 265/50/20's.
File Type: jpg
