3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
intake sensor?
Old Oct 11, 2010 | 09:28 PM
gjmoran's Avatar
gjmoran
Default intake sensor?
i installed the cai from chrome intakes and there is a sensor that was located right before the throttle body on the stock intake. i removed it and was trying to fit it into the new sensor hole on the cai, but it is a little too short to fit in there. so i ended up putting my old intake back on and now after putting that sensor back in there the check engine light is stuck on. what type of sensor is this and how much do they cost?
Old Oct 11, 2010 | 09:44 PM
it is the intake air temperature sensor (IAT). Did you break it or pull the wires out? It should have what looks like a little resistor on the end of it. If you know how, you could just splice some extra length of wire into the harness to make it fit the cai. This is what the IAT should look like:
Old Oct 11, 2010 | 10:19 PM
gjmoran's Avatar
gjmoran
i dont know if i broke it or not but after putting it back in to the original intake i kind of had to man handle it a tiny bit to go back in but my check engine light has been on since i took it out and put it back in. how much do they cost?
Old Oct 11, 2010 | 10:41 PM
not sure, you'd have to check around.
Old Oct 11, 2010 | 10:58 PM
gjmoran's Avatar
gjmoran
is there any certain type of wire i need to get if im going to extend the wires on that sensor? im just kind of nervous to cut the wire and splice it myself.. just because of the water and stuff when it starts raining around here i dont want it like shorting out or something
Old Oct 11, 2010 | 11:18 PM
I just used some spare 20 gauge wire. Get some butt splices, cut, strip, crimp...really easy. and wrap everything with electrical tape or heat shrink tubing. Never had a problem. Someone will probably say this is the wrong way to do it but you get the idea. Nothing will short out, just dont have it running when you do this. take a look at this thread...gives you the basic idea.
https://dodgeforum.com/forum/3rd-gen...re-how-to.html
Old Oct 11, 2010 | 11:27 PM
gjmoran's Avatar
gjmoran
i dont need those resistors right? since im just trying to extend the wire, not alter anything else
Old Oct 11, 2010 | 11:38 PM
Six_Shooter's Avatar
Six_Shooter
No, don't add any resistors.
Just use some 18 AWG wire, I highly recommend against butt connectors, using some heat shrink over a soldered connection, using electronics solder, don't even think about using plumbing solder.
I would then cover the entire pair of connections with some electrical tape, and split loom. The split loom is more for aesthetics, but does add some protection too.
Old Oct 12, 2010 | 01:02 AM
gjmoran's Avatar
gjmoran
awesome thanks for the info. 1 more question though. im not actually sure the sensor is bad. would the check engine light stay on after i tripped it, until i get a computer to reset it? or is there another way to reset the check engine light?
Old Oct 12, 2010 | 01:52 AM
canadian dakota's Avatar
canadian dakota
disconnect the positive cable with the truck off turn the key to the on position for ten minutes turn the key off reconnect the terminal. turn the key to on let the gauges jump around shut the truck off it should be reset... itll take some time for the light to trip as the computer is relearning its self.....
before you do this see i if you can get an O.B.D. II and run a scan it should give you a code and tell you what you need if you have an 08+ you can just shuffle the key to get a code
