3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
gas cap light
Old Jan 8, 2011 | 06:13 PM
wcb362's Avatar
wcb362
Default gas cap light
2008 Dakota 3.7 ....gas cap light came on today I stopped and checked if I forgot to put it on but it was there. When I got home I took the one off the Durango and tried it on the Dakota and the gas cap light came back on I put the Dakota gas cap on the Durango and no problems with it .....any Idea's on what might be the problem????
Old Jan 8, 2011 | 06:39 PM
Eimer123's Avatar
Eimer123
https://dodgeforum.com/forum/3rd-gen...p-problem.html
Old Jan 8, 2011 | 06:48 PM
wcb362's Avatar
wcb362
Thanks I'll give it a try
Old Jan 8, 2011 | 06:56 PM
Eimer123's Avatar
Eimer123
Let us know, and we will work from that
Old Jan 8, 2011 | 07:00 PM
wcb362's Avatar
wcb362
I just went out and unhooked the battery for about 1 min ... I hooked it back up and started the truck and moved it in the drive way and it stayed off... THANKS
any idea what might of caused it ???
Old Jan 8, 2011 | 07:03 PM
rengnath's Avatar
rengnath
Some cars require that you click the cap so many times before starting the engine at a gas station. Or, it will take a few start ups for the light to come back on. It could be something in the EVAP system.
Old Jan 8, 2011 | 07:05 PM
wcb362's Avatar
wcb362
I filled it up yesterday and put about 50 miles on it. I had to go to do some work today and it came on after about 1 mile after leaving the house
Old Jan 8, 2011 | 07:09 PM
rengnath's Avatar
rengnath
Yeah, normally with vacuum operated systems like the fuel tank it will take a while for the CEL to trigger. Could've simply been the fuel cap wasnt locked, and it came on. In order for the CEL to go off, it wouldve had to go through so many start ups with the cap on or the CEL wouldve had to been cleared. Did you get a chance to read the code?
Old Jan 8, 2011 | 07:15 PM
wcb362's Avatar
wcb362
No... I didn't even think about a code, if it comes on again I'll let you know .
It's still under warranty so if it is something to be fixed Dodge can do it The light just bothered me to see the gas cap light on my odometer THANKS FOR ALL THE HELP
