3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Dash noise problems
Old Mar 23, 2011 | 08:25 PM
PapaJohnAZ's Avatar
PapaJohnAZ
Default Dash noise problems
2006 Dodge Dakota (75,000 mi)- Two intermittent problems:
1. When I change selector from floor to dash (actually any change), a loud clicking sound starts from the middle of the dash, and may or maynot stop after a while.
2. Fan speed varies although the speed control has not been touched.
Any ideas would be appreciated, 'cause I love my truck except for this, thanks
Old Mar 23, 2011 | 10:00 PM
FrenicX's Avatar
FrenicX
Sounds like a servo is going out on the vent doors. If not the servo, then the small pinion or gear teeth attached to the door (assuming that's how dodge did it.) It's probably a cheap fix but a PITA because you will probably have to tear your dash apart. I myself haven't done anything to my dash yet, but you might be able to just remove a cover from the under the dash to access the doors.
As for the fan speed, that's tricky. The two issues may be related. Might not get enough power for the servo to work properly with the feed to the system fluctuating.
BTW, Welcome to the forums!
Old Mar 24, 2011 | 05:22 AM
Backwoods18's Avatar
Backwoods18
My truck does the same exact thing. I thought it was normal haha
Old Mar 24, 2011 | 01:51 PM
does the air flow actually change from floor to dash?
Old Mar 24, 2011 | 05:02 PM
Backwoods18
Mine takes like 15-20 seconds.. normal?
Old Mar 24, 2011 | 11:02 PM
FrenicX's Avatar
FrenicX
Mine just makes a small buzz sound that I usually don't even notice if the radio is on or there's road noise. That lasts maybe a couple seconds before the air switches. Then there's a tiny 'door slam' sound and its done. Less than 5 seconds start to finish. Guess I'm a lucky one.
Old Mar 25, 2011 | 04:49 AM
Backwoods18
Hmmm.... I thought it was normal seeing as how the windows take that long to go up as well. HAHA
Old Mar 25, 2011 | 04:44 PM
FrenicX's Avatar
FrenicX
My windows are pretty slow too lol
Old Mar 28, 2011 | 07:21 PM
seeless85's Avatar
seeless85
Par for the course with my experiences as well. Windows and vents. LOL Been like that since about 6 months after I bought it and I'm right at 3 years of ownership. All is well so far. The best fix for our trucks is this lol
Old Mar 28, 2011 | 09:16 PM
same exact way for mine. I had no idea these trucks used electrical servos vs the vacuum motors found on every other car I've owned. I heard it one day and was like wtf is that noise...lol
