3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
What makes it so hard to get HP for 4.7L?
Old Mar 26, 2011 | 09:54 PM
Backwoods18's Avatar
Backwoods18
Originally Posted by Altair
Also keep in mind there's a lot of parts and aftermarket support for the 4.3l V6. It was made for quite a while and was one of GM's best engines along with its big brother 350. It also made a lot of its power very early in the RPM range, I used to have a '93 2wd Sierra with the 4.3 in it.
The 4.3L is equivalent to the 3.7L in popularity. Been around for awhile and proven for endurance and reliabilty. Or am I completely off?
Old Mar 26, 2011 | 10:26 PM
Altair's Avatar
Altair
Dak attack!
Well I don't know if I'd say it's equivalent yet. GM's 4.3l V6 has been around since 1985, the 3.7l was introduced in 2002. The 4.3 also makes peak torque lower in the RPM range, which isn't surprising given the displacement difference. For the 93 Sierra I had it made 235 lb-ft @2000 RPM, the 3.7l makes 235 lb-ft @4000 RPM. So far as I know both are great engines but I can only speak from experience on the 4.3.
Old Mar 27, 2011 | 10:00 AM
I had a 4.3 in a Chevy Caprice (huge car) and in a S-15 Jimmy. That engine had gobs of low end.
Old Mar 27, 2011 | 10:20 PM
Blown287's Avatar
Blown287
How about Ford's new 3.7L in the new Mustang rated at 305hp? With the new supercharger kit at 8psi it's putting down 427 to the wheels.
http://v6mustangperformance.com/worl...rgedv6mustang/
Old Mar 27, 2011 | 10:45 PM
FrenicX's Avatar
FrenicX
Look up the 2010 GT vs the 2011 V6. The GT just BARELY loses in each drag.. if I remember right.. it usually pulled neck and neck in the low range before the V8 in the GT takes over.
I wonder how that I5 is doing in the Colorado/Canyon. Seems to have some good numbers, but I haven't looked up its true performance.
Old Mar 27, 2011 | 11:36 PM
Dakkkota's Avatar
Dakkkota
Who would waste time in a I5 colorado engine...a ls series is a direct bolt on in these truck... you just need gto solid engine mounts or new colorado engine mounts. you can keep the rad...diff transmission etc...
maybe just a bellhousing and a conversion for gas pedal.
Old Mar 28, 2011 | 10:09 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I had a convertible 2011 Mustang with the 6 as rental in Florida and I was very impressed with it! It was fun to drive and wasn't a slouch.
Old Mar 28, 2011 | 11:35 PM
FrenicX's Avatar
FrenicX
A Hertz edition mustang? Or regular? Funny how Hertz was able to get Ford to make specific models just for them.. black with gold racing stripes doesn't look too bad.
Old Mar 31, 2011 | 11:22 PM
FrenicX's Avatar
FrenicX
Originally Posted by ericemery
I didnt know hertz did an 11 edition. I thought it was the "gt350" that they did that for.
Yea I did some checking, the lastest Hertz model looks like the Corvette ZHZ. No new mustang yet.
