amp help
#32
#37
Guest
Posts: n/a
RE: amp help
Trucky, I just have to spot fill sand an paint... should be done late tonight, or tomorrow... I am out of hardener, but I am on my way to the store in a few minutes...
Nowick, I dont think they will know... you will have to send in the radio, but if you call them they might not have you send in the harness...
Call them and see what they want you to do...
#38
RE: amp help
Hey Trucky,
If you intend to run a sub then don't worry about the rear speakers. Get a 2 channel amp to power the fronts. Get an amp that puts out more than what you need . Less strain on the amp than pushing it to it's max output all the time. Then get a mono for the sub. This will sound way better than running front, rears, and a sub. Otherwise the soundstage will be screwed up. If you are very budget minded look at Profile California series amps. Inexpensive but do rated power. I have a AP600 for my comps and an AP700M for the sub. Had them for a year and no problems.
Good luck,
Pepperhead
Good luck,
Pepperhead
#39
