amp help
#51
on
1 Post
ORIGINAL: Frenchy
Ugh Eric.. I'm getting engine noise!!!!!!!!
I think my temp. ground is bad.... anything I have to worry about w/ this?
GRARAEJYALEJRFDMEWAytaeFD saer5k cd
#52
Guest
Posts: n/a
well... engine noise inst good for your speakers, but it isnt terrible... I dont think you will hurt them immediatley, but I am sure they will be damaged over time... I would fix the grounding issue you had... it should clear up after that. we can do that when you get here too... if you dont want to befor taking off...
#54
on
1 Post
ORIGINAL: ericemery
#56
#57
if you have a 4 channel amp, you could bridge two channels together by wiring across both channels for your positive and negative connection. some amps have a bridged mode slider switch, others do not. my rockford punch 160 i bridge and flip a chip on the pcm to tell it perform in hi, mid, or lo mode. now when your talking about running more than two speakers off a bridged channel i get a little nervous. i don't like to have that many wires put together in one channel. it has great potential to fry your amp or damage your speakers.
#58
#60
Guest
Posts: n/a
