electric fan
Old Jun 11, 2007 | 01:55 PM
superdak05's Avatar
superdak05
Default electric fan
www.moesperformance.com had the flex-a-lite black mgic 180 fan for cheap 239.99, comes with all the hardware and electrical connenctions. anyone have experience hooking and using one? or a similiar set up. i know people have used the viper fan but i think this is more for the dakota.
Old Jun 11, 2007 | 02:22 PM
Frenchy's Avatar
Frenchy
Default RE: electric fan
I have an electric fan off of a 1993 Lincoln Continental 3.8L... dual speed elec. fan at 2500cfpm and 5000+cfpm... the wire connector has three wires... a ground, high, and low...
Same size as the radiator, has the shroud, and everything...
I just went to a local salvage yard, found the best looking one they had, cut the connector, unbolted the two 7/16 bolts, and pulled it off...
20 dollars, well spent.
Old Jun 11, 2007 | 02:37 PM
slaterracing's Avatar
slaterracing
i used something like that kit on my 85 mustang. i used 2 12 inch fans and mounted them in the front so i cleaned up the engine bay a lot. also helped with power. not hard to do. using that kit will make it nice and easy
Old Jun 11, 2007 | 03:01 PM
rookie's Avatar
rookie
french', have you installed that thing yet? Sounds like an easy way to steal a few ponies.
Old Jun 11, 2007 | 04:23 PM
Frenchy's Avatar
Frenchy
I have everything ready, except the relays...
Jimbo sent those out to me Saturday, I believe, and they should be here tomorrow...
All I'm doing, is wiring it up to the steering columns power cord, then running a switch, JUST IN CASE, I ever need the extra 2500cfpm from the high setting, it should take all of, 15 minutes to do.... holding it to my radiator via radiator ties..
Don't worry, unlike everyone else, when I do this, I'll have a how-to, with pics from the WHOLE install, not just the finished result.
Old Jun 11, 2007 | 04:30 PM
DakotaStone's Avatar
DakotaStone
Good idea Frenchy. I'm going to have to look around for something like that. Too bad I can't find some cams and a S/C for my truck.
Old Jun 11, 2007 | 09:59 PM
pro4x4's Avatar
pro4x4
I have the black magic fan #180. I also got the variable speed control which is extra. The instructions are pretty good as far as wiring it. Mounting the fan takes a little time and you have to cut the mounting brackets to make it work. Check out my cardomain link and you will see pictures of my install.
Old Jun 12, 2007 | 12:26 AM
Altair's Avatar
Altair
Dak attack!
ORIGINAL: DakotaStone
Check out http://www.krcperformance.com
Old Jun 12, 2007 | 01:06 AM
Altair's Avatar
Altair
Dak attack!
Oh, and Frenchy, would you mind posting a few pictures of the fan just sitting out somewhere? I want to get one but it would help if I knew what it looked like when I'm running around the junkyard.
Old Jun 12, 2007 | 02:12 AM
Frenchy's Avatar
Frenchy
I'll get you those pics tomorrow sir...
