people with electrical knowledge...
Old Jun 19, 2007 | 04:18 PM
Frenchy's Avatar
Frenchy
Default people with electrical knowledge...
I am going to install a switch for my e-fan, so if I need to, I can run my fan on the high setting (which I doubt I'll ever need) but anyways, the switch I have is a 2-pin I/O switch... the pins aren't labeled with a +/- so I don't know which one too hook up to a ground, and which to hook up to the power...
Help me?
plleeeeeeeeeease!
Old Jun 19, 2007 | 04:37 PM
Frenchy's Avatar
Frenchy
Default RE: people with electrical knowledge...
so after looking at it more...
I'm assuming the post in the middle of the switch is my ground... this correct?
Old Jun 19, 2007 | 06:53 PM
Altair's Avatar
Altair
Dak attack!
Pics of the switch? Or a model number perhaps? It might not even matter which one is which to be honest but don't blame me if anything bad happens.
Old Jun 19, 2007 | 07:21 PM
Frenchy's Avatar
Frenchy
http://www.radioshack.com/product/in...2062523&cp
Old Jun 19, 2007 | 08:02 PM
Altair's Avatar
Altair
Dak attack!
Ok it doesn't matter for that switch. Any SPST (Single Pole Single Throw) switch it doesn't matter which side goes to power and which to ground. All it does is make or break a single connection.
Old Jun 19, 2007 | 08:04 PM
turbot_bird's Avatar
turbot_bird
is there 2 or 3 conecters on the back? if its 2 one would be power in and the other power out. if there is 3 then one should be a different color and thats the ground, usually the middle one. but I might be wrong.
Old Jun 19, 2007 | 08:49 PM
Frenchy's Avatar
Frenchy
its two pin...as stated in my first message... lol...
and what do you mean power in power out??
Old Jun 20, 2007 | 02:03 AM
turbot_bird
well all the ones ive done had the two conecters and one had I wire from a power source then the other was the power coming out of the switch to the object (your fan)
Old Jun 20, 2007 | 02:19 AM
Frenchy's Avatar
Frenchy
Ya, thats what my friend told me, and it's working fine, he has an associate's degree in electronics engineering... or something, so I figured he'd know what I should do....
And it works fine! :-)
Old Jun 20, 2007 | 02:22 AM
turbot_bird
cool, glad it works for you lol
