i was curious as to how the DAKs with level kits or lift kits are holding up? has anthing worn out yet? Lifts tend to cause something to wear prematurely..... how long have the lifts/level kits been installed? is the factory ride completly thrown down the drain? I heard after 6 months with the level kit something in the front 4wd will HAVE to be replaced...?
Ive had my TM leveling kit and 2" aluminum block lift installed for about 4 mo. No problems yet and rides good. But, I have been getting this groan and creek in my steering wheel and I wonder if its related. Does anyone know what that is??
it handles better but since i switched out the gears it still breaks the back end loose. noticed that the ride is not as bumpy. but the frt still has the sway in it.
I dont think you have anything to worry about with the TM kit. The CV's arent at this extreme angle thats going to make a big wear difference. Were talking about 1.5" of lift.
If the point of this post is to see if you should invest in the TM kit, then thats the one to get.
