LED Question
Old Jul 17, 2007 | 06:19 PM
Night_Runner's Avatar
Night_Runner
Default RE: LED Question
it is for my liscense plage lights....are you sure i need them
Old Jul 17, 2007 | 06:26 PM
bad venge's Avatar
bad venge
Section Moderator
no running lights are fine without resistors ...led's save power use by pulling very little current
the load resistors make it so your turns go at a normal rate ... the led's pull so little that the blinkers will "flash" at warp speed , the resistors pull the same load as the old bulbs ...
http://www.superbriteleds.com has some good prices and explanations
Old Jul 17, 2007 | 06:27 PM
mb18's Avatar
mb18
You do not need resistors for any lights that don't blink...license plate lights, backup lights, for example.
Old Jul 17, 2007 | 06:39 PM
chopperzen's Avatar
chopperzen
oh. no. not for plate lights.. sorry what kind of bulbs are they? Any 3157 bulb replaced with same size LED would need a leq. That would include brake and reverse..
Old Jul 17, 2007 | 07:36 PM
Altair's Avatar
Altair
Dak attack!
Why would reverse need a load eq? I don't see how they could possibly stay on, there shouldn't be any voltage there unless you're actually in reverse.
Old Jul 17, 2007 | 07:45 PM
bad venge's Avatar
bad venge
Section Moderator
like mentioned only the turns need them ... brake, reverse, running,plate,dash lightsare fine without them ....
Old Jul 17, 2007 | 07:55 PM
mb18's Avatar
mb18
Exactly. Specifically, for the Dakota's exterior lights...the backup and plate lights are the only ones that do not need the load resistors. Since the brake lights and rear turn signals are the same bulb, you do need load resistors here and for the front turn signals.
I'm installing mine on Saturday.
Old Jul 17, 2007 | 09:11 PM
coondog05's Avatar
coondog05
i have blue leds (not brakes)in all lights and ONLY blinking lights have resistors
Old Jul 18, 2007 | 01:15 AM
Night_Runner
alright thanks guys. appreciate it...you think there would be much differance in interior lighting color/brightness to replace the lights on the roof of the cab that 1-come on when door is open, or 2-come on when you manually push them...
Old Jul 18, 2007 | 02:34 AM
Night_Runner
i just ordered this as well for my reverse.
http://frickinbrite.com/catalog/prod...roducts_id=367
also, what is up with this pending crap under "order history" on bottom left? my paypal acct acknowledges v-leds has been paid for both items.
[IMG]local://upfiles/46457/842A9C99E8F34AB5B004A2EF9246005B.jpg[/IMG]
[IMG]local://upfiles/46457/B797DF7FDFE54E1F95627C836DD9F11F.jpg[/IMG]
