What have you guys done with your V6
Old Sep 7, 2007 | 01:21 PM
HuffDaddy's Avatar
HuffDaddy
Default What have you guys done with your V6
Ok I need a little input from you V6 guys; what mods have you done to boost power and what ones have you personally experienced results from? I am itching for a new mod and cant decide which way to go.
Old Sep 7, 2007 | 01:25 PM
Cuban11182's Avatar
Cuban11182
Default RE: What have you guys done with your V6
Trade it in and get a V8 Just kidding...what about the jet chip?
Old Sep 7, 2007 | 01:49 PM
HuffDaddy's Avatar
HuffDaddy
I sell emso I can onlybuy them when the deal is right, unfortunately when it was right we were out of v8's. I was thinking of the jet chip but I want to do a couple other mods first and then get a stage 2.
Old Sep 7, 2007 | 10:18 PM
luvmydak's Avatar
luvmydak
Not necessarily in this order: less restrictive exhaust, dump the resonators, get a Flowmaster muffler- your choice as to the sound you like (Meineke does a nice job); K&N cold air intake; 180 t'stat along with the Jet StageII; TB from the Fastman. Definite improvements in throttle response and MPG.
Old Sep 8, 2007 | 09:13 AM
HuffDaddy's Avatar
HuffDaddy
Luvmydak, is your truck a V6? I have the whole flowmaster/no resonator thing going for me allready (see signature) I figured that the Cold Air deal was next but I just cant see paying almost $300.00 for an intake. I am considering buying the one on e-bay, replacing the junk filter that comes with it and building an aluminum heat shield.
Old Sep 8, 2007 | 09:20 AM
luvmydak's Avatar
luvmydak
Mine is an '05 v6
Old Sep 8, 2007 | 10:12 AM
vandutton's Avatar
vandutton
luvmydak, where did you get your 180 tstat?
Old Sep 8, 2007 | 11:44 AM
luvmydak's Avatar
luvmydak
Online at www.summitracing.com Part# 10177. As I recall, it was around $31 which was cheaper than from Jet. Did not require any additional gasket as it is built in. The thermostat is located where the LOWER hose goes into the block. Important- drain your radiator first, otherwise youwill have a gusher. If your antifreeze is still clean, reuse it after the install.
Old Sep 9, 2007 | 10:26 AM
HuffDaddy's Avatar
HuffDaddy
Luvmydak, what kind of gains have you experienced? Better MPG? If so what do you average? Which of your mods do you feel made the most difference?
Sorry for the list of questions but it sounds like you have exactly every mod that I want. I was reading reviews on autoanything for the jet chip and it seems that everyone with a 3.7 (commanders in this case) gave it a bad rating but overall it scored well. Do you think that they are just knocking it because it did not convert ther motor into a V8??
Old Sep 9, 2007 | 11:47 AM
vandutton's Avatar
vandutton
Summit says the t-stat is for the V8. Is that the one that will work on ours?
