upgrade to forum?
upgrade to forum?
As we all may well know every day topics are recycled and talked about numerous times, whether it's what mods to do first, if the turbonator works, yadda yadda the list goes on. only somewhat annoying. but when people want to see pictures that we have alread posted it would be nice to say it's in the archive do a search. is there any way to get an inter-forum search on here to root up old topics/pictures/discussions? it would make life so much easier...
RE: upgrade to forum?
ORIGINAL: shrpshtr325
there alread is a search, at the bottom of the page there are 2 bars and the bottom one is a search, and then also at the top there is a link that says search that lets you be more specific/general in where and what you want to search for
ORIGINAL: trucky
Trending Topics
That sounds more like a routing problem at your end. I assume if your on a T-1, your part of a larger network. What you describe, sounds like an issue with routing from this IP address. Since your the only one (that I know of) with this issue constantly, it would most likely be at your end. What you can do to test it, is ping or tracert this website name or IP address, that should let you know where the issue is.
Here is what it would look like with a TraceRT
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\********>tracert www.dodgeforum.com
Tracing route to www.dodgeforum.com [209.234.248.12]
over a maximum of 30 hops:
1 2 ms 1 ms 2 ms 192.168.1.1
2 8 ms 11 ms 12 ms 10.177.10.1
3 10 ms 7 ms 15 ms gw01.ajax.phub.net.cable.rogers.com [66.185.90.3
3]
4 8 ms 6 ms 7 ms 24.153.5.157
5 9 ms 43 ms 10 ms so-4-2-0.gw02.ym.phub.net.cable.rogers.com [64.7
1.240.189]
6 11 ms 9 ms 9 ms so-2-0-0.gw02.bloor.phub.net.cable.rogers.com [6
6.185.80.165]
7 22 ms 21 ms 21 ms so-1-0-0.igw01.chcrmk.phub.net.cable.rogers.com
[66.185.81.190]
8 20 ms 19 ms 37 ms ge3-1.fr3.ord.llnw.net [68.142.72.213]
9 72 ms 71 ms 72 ms tge1-3.fr4.sjc.llnw.net [69.28.171.66]
10 77 ms 69 ms 79 ms ve5.fr3.sjc.llnw.net [69.28.171.209]
11 79 ms 88 ms 80 ms tge2-3.fr4.lax.llnw.net [69.28.171.117]
12 78 ms 76 ms 97 ms cdnconsulting.tge9-3.fr4.lax.llnw.net [68.142.78
.118]
13 81 ms 80 ms 79 ms 209.234.248.12
14 80 ms 79 ms 81 ms 209.234.248.12
15 81 ms 84 ms 94 ms 209.234.248.12
16 81 ms 82 ms 79 ms 209.234.248.12
Trace complete.
C:\Users\******>
3]
1.240.189]
6.185.80.165]
[66.185.81.190]
.118]
Trace complete.
C:\Users\******>
