Running Fogs with High Beams
Old Dec 18, 2007 | 02:39 PM
babygotdak's Avatar
babygotdak
Default Running Fogs with High Beams
Has anyone figured out how to do it?
Old Dec 18, 2007 | 03:50 PM
graythang's Avatar
graythang
Default RE: Running Fogs with High Beams
Well this use to be a very simple thing and it still might be but as in the past it was just jumper the relay but the function is now handled by the puter with the CAN-B program. It handles the turning off the fogs when the highs are on and also handles the battery saver for the fogs if left on once the key is pulled. So the relay set up is not what it uses to be. If 12V is still supplied to the fogs once the highs are turn on this will work but theputer may see it as a malfunction. Also if you have auto light function it is also tied into this but the fogs should turn off with the headlights in any case. If anyone has done this with a GEN III please chime in. I'lllook at the circuit in the service manual when I get home from work and chime back in later.
Old Dec 19, 2007 | 05:56 PM
scottscan's Avatar
scottscan
hey babygotdak , i am running this on mine. the o.e.m. foglight relay uses a negative ground trigger to turn the foglights on .i used another relay toswitch ground to the o.e.m. relaywhen thehighbeams are on. tap on to the highbeam wire, run this to the switch terminal on the#2relay. then wire the battery terminal on#2 relayto ground. then send the output terminal on #2 relayto the switch terminal on the o.e.m. relay.instead of relaying + (battery) it switches ground. i ran this on my 2002 dakota also. hope this helps !!!!!
Old Dec 20, 2007 | 02:16 AM
Cuban11182's Avatar
Cuban11182
scott can u draw a quick schematic?
Old Dec 20, 2007 | 08:49 AM
studlyblueiz's Avatar
studlyblueiz
I drew one up based on his instructions. Although, I took the assumption that the Relay terminal that is usually ground(-) to be battery(+). Scott didn't say...so here ya go. He should confirm it right tho.
***Just noticed: I believe it's slightly wrong with the info given by Scott. I should have shown the fog light not being grounded I guess but as + b/c I set it up as the relay's receiving a ground to cut lights on.
Old Dec 20, 2007 | 11:16 AM
studlyblueiz
The only downsides I can see with that is:
[ul][*]You can't turn them off when your highs are on.[*]Amperage draw on alternator[/ul]
The amp draw could be bad for those with efans, audio systems, etc
Old Dec 20, 2007 | 01:04 PM
Destructicon's Avatar
Destructicon
But what if your running a battery cap with your audio system? I'm not a stereo guru but my younger brother swears by them. I know they are there for that extra punch/draw from the stereo but wouldn't this help eliminate the amount of power that a system would draw from the alternator?
Of course you could be like the jackasses with more money than brain cells and run your auxilary sytems from an independant battery.
Just a thought...
Old Dec 20, 2007 | 01:29 PM
viper359's Avatar
viper359
Just wondering why you would want the fogs on when the highs are on. I make no judgement, just trying to figure out the benifits to the work.
Old Dec 20, 2007 | 02:42 PM
ChadJK's Avatar
ChadJK
ORIGINAL: studlyblueiz
[ul][*]Amperage draw on alternator[/ul]
If you got the "Trailer Tow Group" with your Dakota, then it should come with an upgraded alternator and battery.
Old Dec 20, 2007 | 03:51 PM
studlyblueiz
I have the tow package and only remember hearing transmission cooler in that deal...
Either way if one didn't it could still pose a prob.
