full time 4x4 rear end
Old Mar 27, 2008 | 04:09 PM
Soapy's Avatar
Soapy
Default full time 4x4 rear end
There were some questions a while ago about which rear end you get if you order the full time 4x4 package. It does come with the 9.25 rear end if you have the 4.7 V8.
Old Mar 27, 2008 | 07:22 PM
Racinartist's Avatar
Racinartist
Default RE: full time 4x4 rear end
Not on the '08. My TRX is full-time FWD and I have an 8.25" rear with 3.92 gears.
Old Mar 27, 2008 | 08:30 PM
Frenchy's Avatar
Frenchy
full tiem front wheel drive?
You mean 4WD?
Old Mar 27, 2008 | 10:44 PM
Soapy's Avatar
Soapy
My dakota is a 2008 TRX4 4x4 with full time and it has a 9.25 rear end. I also have the trailer tow pkg. I don't know if that makes the difference.
Old Mar 28, 2008 | 07:18 AM
Antjmar's Avatar
Antjmar
Soapy are you sure?Its hard to tell the size its only 1" diff. How many bolts on it? I have a 2006 TRX4 AWD with tow package (3.92 gears) and the 4.7 and its an 8.25. Surprised they would increase the size...
Old Mar 28, 2008 | 08:09 AM
Racinartist
If you go to the 'build' section on Dodge's website, it doesn't show ANY Dakota available with anything but the corporate 8.25" rear for '08. I seriously doubt your '08 has the 9.25" dude, sorry.
Old Mar 28, 2008 | 01:42 PM
RamItOne's Avatar
RamItOne
ORIGINAL: Frenchy
You mean 4WD?
Frenchy you gonna redact your statement about 3rd gen ramers being tards?
Old Mar 28, 2008 | 02:37 PM
Frenchy's Avatar
Frenchy
Huuuuush hush, Ramit.
Old Mar 28, 2008 | 02:42 PM
ptschett's Avatar
ptschett
I'd check the sticker in the glovebox before concluding one way or another. Build and price sometimes is on crack.
Also, look at "specs and upgrades" on a Laramie... on those the 4.7L is standard now, and the website correctly indicates the 9.25" as the axle used.
Edit: another way to know is to check the diff cover shape... 8.25" are a little rounder, 9.25" have a definite octagonal shape.
Old Mar 28, 2008 | 03:00 PM
mawashi's Avatar
mawashi
I just took delivery of an '08 TRX4 with 4.7l V-8,full-time transfer case with AWD, tow package, 3.92 gears and just about every option you can get and it has the 8.25" axle. I was the one who originally posted the question about Dodge using 8.25" axles for full time 4WD and 9.25" axles for part time 4WD. Go to any Dodge dealer and pick up the brochure on the '08 Dodge Dakota and you'll see in the specs page, that 4.7l V-8 Dakotas with either 2WD or Part Time 4WD get the 9.25" axle and Full Time 4WD gets the 8.25" axle.
