Locker or limited-slip??
Old Nov 21, 2008 | 07:21 AM
tankmechus's Avatar
tankmechus
Default Locker or limited-slip??
Anyone know where to get an aftermarket limited-slip or locker for our rear axles??
Old Nov 21, 2008 | 09:18 AM
sdsdsd's Avatar
sdsdsd
I would think your local speed shop.
Old Nov 21, 2008 | 09:38 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Like sdsdsd said or look one up online, its just a 9.25 dodge/chrysler rear end...
Old Nov 21, 2008 | 12:32 PM
superdak05's Avatar
superdak05
stay away from the locker. only used in the dirt or sand. you wont like it on the street. they tend to pull to one side. just go to dodge and ask for a corporate rear for your year truck. corporate is the posi set up when the tires spin. not that one legger stuff
Old Nov 21, 2008 | 03:34 PM
cramerica's Avatar
cramerica
Hmm, my build sheet lists my 9.25" as a "Corporate" axle, and it is a professional one-legger. I think the LSD's are called Anti-Spin Differentials in the build sheets. They are also supposed to be highly susceptible to failure, search "C-Clip" in the 1500 Ram forums. I would stay away from a factory LSD. Google and see what you like. The Detroit Truetrac seems like a pretty solid and wear-proof unit.
https://www.rearendparts.com/product...23&page=1&js=n
Old Nov 21, 2008 | 06:11 PM
mprohr's Avatar
mprohr
I don't know what you guys are talking about when refering to corporate. My truck came with the Dodge posi rear-end...I believe the factory posi is a quality product. The limited slip units are low rent. I have heard horror stories about aftermarket lockers for street use. If it's a dirt truck, by all means get a locker.
Old Nov 21, 2008 | 06:58 PM
superdak05's Avatar
superdak05
if your sht says corporate and only one tire spins then it is either a misprint or your housing is busted. my corporate leaves two very nice blk strips when i take off. might want to take a look into it
Old Nov 21, 2008 | 09:59 PM
flyboy1304's Avatar
flyboy1304
mine has the Corporate... and it lays down some rubber no problems thus far
Old Nov 21, 2008 | 10:06 PM
lghtngblt02
hmmmm, this is what I received from dodge, awhile back
From: customerassistre [customerassistre@chrysler.com]
Sent: Tuesday, February 19, 2008 11:15 AM
To: William Bolt
Subject: Re: Chrysler LLC Customer Assistance (KMM5518941I25261L0KM)
Dear William,
Thank you for contacting the Chrysler Customer Assistance Center regarding your 2007 Dodge Dakota.
According to our records, your vehicle was equipped from the factory with the following:
Leather Trimmed Bucket Seats
Med Slate Gray
Heavy Duty Service Group
Interior Convenience Group
Sport Appearance Group
Trailer Tow Group
Security Group
Convenience Group
Power Convenience Group
Monotone Paint
136 Amp Alternator
750 Amp Maintenance Free Battery
Run Down Protection Battery
Pwr Disc/Drum Rr Anti-Lock Brakes
Bucket Seats
Premium Door Trim Panel
Manual Driver Lumbar Adjust
Rear 40/40 Folding Split Seat
Passenger Air Bag On/Off Switch
Advanced Multistage Front Air Bags**
Front Seat Area Carpet
Front Floor Mats
Passenger Assist Handles
Driver Assist Handle
Floor Console
Overhead Console
All 5-Speed Automatic Transmissions
5-Spd Automatic 545RFE Transmission
Elec,Shift-on-the-Fly,P/Time T/Case
205MM Front Axle
3.55 Axle Ratio
Corporate 9.25 LD Rear Axle
4.7L V8 MPI Engine
Tinted Glass Windows
Tinted Windshield Glass
Front Door Tinted Glass
Full Swing Rear Doors
Deep Tint Sunscreen Glass
Rear Window Defroster
Rear Fixed Window
Rear View Day/Night Mirror
Driver Side Sun Visor
Passenger Side Sun Visor w/Mirror
Power 6X9 Multi-Func F/Away Mirrors
All Vehicles W/Power Mirrors
Keyless Entry
Sentry Key Theft Deterrent System
Air Conditioning
Hood Insulation
Instrument Panel
Instrument Cluster w/Tach
Instrument Panel Satin Silver Bezel
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Dual Note Electric Horns
12V Auxiliary Power Outlet
12V Center Console Power Outlet
Power Accessory Delay
Power Locks
Power Windows, Driver One-Touch
Heated Front Seats
Power 6-Way Driver Seat
STRIPE/BADGE/MOLDING COLOR
Illuminated Entry
Key in Ign/Seat Belt Warning Buzzer
Headlamps On Warning Chimes
Door Ajar Warning Lamp
Rear Dome Lamp
Halogen Headlamps
Automatic Headlamps
Fog Lamps
Cargo Lamp
CHMSL Lamp
Security Alarm
Painted Front Bumper
Argent Rear Bumper
Black Headlamp Bezels
Body Color Grille
Ram's Head Badge
Black Windshield Moldings
Chrome Bodyside Molding
Laramie Badge
Dakota Badge
4X4 Badge
Dual Position Tailgate
California Emissions
22 Gallon Fuel Tank
Auxiliary Transmission Oil Cooler
Power Steering Cooler
Speed Control
Heavy Duty Engine Cooling
Next Generation Engine Controller
Bright Silver Metallic Clear Coat
AM/FM CD 6-Disc MP3 Radio
Fixed Long Mast Antenna
Steering Wheel Mounted Audio Ctrls
276 Watt Amplifier
6 Alpine Speakers
Sirius Satellite Radio
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Heavy Duty Suspension
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Rear Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
P265/60R18 OWL On/Off Road Tires
Goodyear Brand Tires
17" Steel Spare Wheel
18X8.0 Aluminum Wheels
Remote Start System
Pickup Box
Scissor Type Jack
Class IV Receiver Hitch
7 Pin Wiring Harness
Universal Garage Door Opener
Brake/Park Interlock
Instrument Panel Parts Module
Tire & Wheel Parts Module
For More Info, Call 888-539-7474
1-Year Service Provided by SIRIUS
Build To U S Market Specifications
California Emissions Order Code
3 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
If you have any further questions, please feel free to contact the Customer Assistance Center at 800-992-1997.
Thanks again for your email. We value you and your business.
Sincerely,
Steve Rogers
Customer Service Representative
For any future communications related to this email, please refer to the following information:
REFERENCE NUMBER: 17228718
EMAIL CASE NUMBER: 1948760
REPLY LINK: http://www.chrysler.com/wccs/brand_f...941I25261L0KM&
bt I get the one legged burn out and I even jacked the *** up and the wheels spin opposite directions...
