Stripped Bolt on Manifold
I was installing header's on my 2005 dodge dakota and stripped two bolts on the manifold. One is on the lower part and the other one is on the upper part of the manifold. Any ideas how I would get these bolts off? I do not have much knowledge of which kind of tools I would use so if I need a drill bit, what kind of drill bit do I need? Anyways, any help would be appreciated. Thanks.
Guest
Posts: n/a
I am not sure what the tool is actually called... but we call them an easy out...
here is the first thing I found on google...
http://www.toolprice.com/category/screwextractors
Guest
Posts: n/a
Trending Topics
I don't think the easy out will fit. Hopefully the PB blaster will loosen it up. Also, the bolt I'm having problems with is on the lower part of the manifold, it's not close to the valve seals, so I'm not sure if the torch will have an effect on it. I might let the truck run for a little bit to get the manifold hot, maybe then the bolt will come out. I'll post back with any solutions.
