Old school leveling blocks going to the milling machine.
Old Dec 21, 2008 | 03:56 PM
Cuban11182's Avatar
Cuban11182
Default Old school leveling blocks going to the milling machine.
My father has a friend that has a milling machine. I have the old set of leveling discs, the aluminum ones that we supposed to first go on top of the tower, then into. I know they have a new type that goes on top of the tower. My question is, the discs are only about 1.5 inches tall, how much should I remove? Thanks
Old Dec 21, 2008 | 04:53 PM
Cuban11182's Avatar
Cuban11182
Ok they are 7/8ths of an inch, kinda don't see how they can level it 2 inches?!? What should I remove?
Old Dec 21, 2008 | 09:59 PM
donkeypunch's Avatar
donkeypunch
King Jackass
If you take a look at your suspension setup, the bottom of the shock lies about half way in between the wheel hub and fulcrum point (the point where the control arm pivots). When you increase height 7/8" at the middle of the arm, the distance at the end of the arm (where your wheel is) is increased at a multiplication factor. The same concept applies to: if you were holding a baseball bat parallel to the ground and move your hands 3" to the right. How far does the end of the bat travel? The answer is based on the length of the bat, but you get the picture.
Old Dec 22, 2008 | 08:16 AM
Cuban11182's Avatar
Cuban11182
I'm not very good with math, so what would you say would be a good amount to remove to get about 1.5 inches of lift so that I don't have any binding issues with the 4x4 like the new kit does?
Old Dec 22, 2008 | 09:50 AM
donkeypunch
King Jackass
If you do the math, you should be able to remove .219" at the spacer. This would take away about .500" lift. However, there are other considerations with the suspension setup that may not get you to exactly 1/2". Personally, the TM techs mentioned that the 2" spacers caused ball joint failure, not CV bind. When I installed my leveling kit, it was designated as a 1.5" leveling kit. I did not measure the spacer to verify, but I did see the front end pop up about 1.5". I have a 4x4 with no cv issues.
Old Dec 22, 2008 | 10:23 AM
Cuban11182's Avatar
Cuban11182
Do you go offroading or anything. I'm not talking launching it or anything, but I live on the beach and may do a little trail riding, nothing extreme.
Old Dec 22, 2008 | 01:02 PM
donkeypunch
King Jackass
I live in Colorado and off-road quite often.
Old Dec 22, 2008 | 05:32 PM
Cuban11182's Avatar
Cuban11182
So do you think I should just have them installed the way they are and not mess with them?
Old Dec 23, 2008 | 09:50 AM
canadiandodge's Avatar
canadiandodge
donkey which system did you buy
Old Dec 23, 2008 | 02:53 PM
donkeypunch
King Jackass
My system locates between the strut mount (on the chassis) and the assembly, NOT in between the spring and inside/top of the strut assembly.
