Mass Thread to complain about Bad Struts
#61
Yeah I know I can do it without removing the spare... but I figure it'll give me more room to work. The spare is something I need to fix anyway... think I've read the safety is catching and not letting it drop. The cable slides down, and the tire only drops like two inches.
#62
#63
I'm experiencing bouncing over what they call speed humps here. The truck bounces at least 3 times after driving over them. So I bought the Monroe Quick-struts (a fully loaded strut) for the front and the Monroe load balancing shocks for the rear. I attempted to put the Quick-struts in, but I could not get the original strut out. So not sure if I'm going to follow the advice on the forms and remove the bolt on the upper arm or just take it to a shop. Gonna try to do the shocks, but I have to find out why my spare doesn't drop before I can do the shocks.
#64
171100 - 4WD
271100 - RWD
Not sure what the difference is between the two as there length specs are the same, but the springs might be stiffer on one vs. the other. I had to buy mine at rockauto... they were about $164 a piece I think. I also used their 5% off coupon. You're welcome... I just figure might as well replace it all... should fix the bounciness.
#65
Part numbers for the '06 V6 and V8 quick-struts are:
171100 - 4WD
271100 - RWD
171100 - 4WD
271100 - RWD
#66
Shocks
Not sure if this is a dumb question, but I see how to get the upper mount loose on the passenger side... but it looks like the upper mount nut on the driver's is in the frame with some piece of metal... is it one piece holding the bolt? I don't see an easy way to access it and torque to the proper spec.
#67
Or not, but you may be able to wiggle a wrench in there, try it, it is spins someone else will chime in
#68
I had to remove the spare so I could get up in there with a grinder. First I cut the shock out of the way, then I cut the bolt short enough to remove the nut end through the little space between the frame and box.
Lets just say it took me longer to get the spare out of there than grinding the shock and bolt out of there. That spare mechanism is the damdest thing. I haven't put my spare back in place yet. On long trips it gets thrown into the box because if I had to go through what I did to get that thing out of there on the side of a highway, I think I'd rather burn the truck.
#69
Just looked at this quick, but if you're talking about the drivers side upper shock bolt, there is a tabbed nut so you can just turn the bolt loose and the tab holds the nut. Unless like when I was doing mine the tab on the nut breaks...
Also I dunno if anyone has shown the difference, but attached is a picture of the TRX4 shock next to the load bearing one. The TRX4 compresses real easily in the beginning (hence my bouncing) and stiffens as it's pushed down further. It could be over extended too, but they look to be about the same height.
Also thanks to everyone who responded... I really appreciate the help and information.
