i need to run through emissions on monday and was wondering IF i should put the truck back to stock tune or just run it threw with the performence tune? does it matter? cant find any info....
all depends how they do it. most places dont put the truck on the rollers any more. they use their scanner and log into the trucks ports to see if it is ok. depending where you go, bring your tuner along just incase.
on
well it shouldn't matter because with our vehicles as long as the check engine light is not on it should pass. cause all they are checking for is to see if everything is reading like it should. cause i have headers on my truck and high flow cats and exhaust that comes out the side. and its fine with emissions i get done. so you'll be fine.
its a butterfly valve (in a y-pipe) in my exhaust before the muffler that when opened lets out the exhaust without passing threw the muffler...headers then cats then out.... sounds good! google it, to see what it looks like
