Installing a JL Audio Subwoofer (Quad Cab)
Old Feb 27, 2009 | 07:05 PM
dakolorado's Avatar
dakolorado
Default Installing a JL Audio Subwoofer (Quad Cab)
I wanted some more bass in my truck and having a quad cab before I knew there was space behind the rear seat. I decided to go with a single JL Audio 10W1v2 behind the seat.
The enclosure is 13.5x13.5x7.5Bx3T equates to roughly a .30 box for a single 10. JL audio subs sound great any almost any enclosure. This sub was designed for a .6 cube ft but this enclosure works and it plays tighter due to air restrictions and keeps the coil centered better giving it better thermal handling capabilitys. The sub handles 300 watts RMS and plays low for a single 10. JL IMHO is simply the BEST!
Remove the two outer T50 bolts on the lower section of the top half of the seat.
Slide Up and out.
Sit enclosure inside the space behind the seat and simply bolt the seat back on.
Total time, 10 minutes. Amplifiers can be placed under the rear or front seats or behind the passenger side rear seat. Havent decided on that just yet.
Finished product.
Old Feb 27, 2009 | 07:16 PM
Cuban11182's Avatar
Cuban11182
Looks nice. Can the seat top be put back on?
Old Feb 27, 2009 | 07:29 PM
dakolorado's Avatar
dakolorado
Yes, absolutely! You wont be able to fold it up though.
Old Feb 27, 2009 | 09:35 PM
mprohr's Avatar
mprohr
Here is a project for you. Find a nice solid woofer grille to install over the JL. Go to the junkyard and find that seatback. Then modify the seat to accomodate the box. You could weld in U braces. Uncomfortable, but functional. Make sure if you add fabric to the back, it is as air transparent as possible. Speaker grille cloth, or similar. No vinyl, pleather, or leather. It would be slick to have the stock look back. Besides, if you're going to lose the seat, you might as well build a bigger box. I installed car and home systems for about 8 years. I've always been a Polk guy. Go ahead, impress me
Old Feb 28, 2009 | 01:55 AM
dakolorado's Avatar
dakolorado
I dont lose the seat or the comfort. That is the beautify of this. Dont need a bigger box. Trucks even 4 doors are a small cab so no large ghetto blasters needed.
Old Feb 28, 2009 | 10:45 AM
mprohr's Avatar
mprohr
Sorry, you can't fold up the BOTTOM part. My mistake.
Old Feb 28, 2009 | 10:47 AM
mprohr's Avatar
mprohr
I'd still recommend a woofer grille.
Old Feb 28, 2009 | 10:50 AM
dakolorado's Avatar
dakolorado
I have thought about it because jl makes one just for their subs that ifts on the existing ring. But its not needed, once the seat goes back on there is nothing going to hit it.
Old Feb 28, 2009 | 10:54 AM
mprohr's Avatar
mprohr
Yeah, I'm just saying....It never hurts to have more protection. I've seen lots of mishaps with woofers, and If JL already makes it, you won't have any excursion issues.
Old Feb 28, 2009 | 11:48 PM
LB's Avatar
LB
Will the seat lift up at all? All I would need is to get at the crap under the seat, never have left it up.
HaHa, kinda reminds me of my wife and "other seat left up"...
PS- did you make the enclosure?
LB
