Outside Air Intake Question
Old Mar 5, 2009 | 02:52 PM
  #21
Frenchy's Avatar
Frenchy
too many words, so im posting my advice...
Get a cone filter...
If you have fog lights, remove them...
place a filter in the passenger side opening, but cover it with a waterproof, but breathable cover...
then run abs plastic up to throttle body, but somewhere in there, put a filter in there that would absorb any potential water that will get sucked up through the filter, and voila
Cold air intake.
Old Mar 5, 2009 | 05:14 PM
  #23
NJJer's Avatar
NJJer
Originally Posted by lghtngblt02
Ducts on both sides?
Just on the passenger side.
I am getting a junk fender from a scrap yard and a guy I know who does louvers in sheet metal is going to use a die and see if we can make a NACA duct in the topside of the fender.
It may stretch to the point of splitting, so then we will know that route won't work. Then we will cut it out and weld in a metal one.
Still in the designing phase at this point.
Old Mar 5, 2009 | 05:18 PM
  #24
NJJer's Avatar
NJJer
Originally Posted by ericemery
Water will hurt almost any true cold air intake...
NACA ducts are a great idea, but reducing turbulence may be fun... I am really looking forward to seeing it. (good luck man, I hope it works out for you!)
Thanks Eric
Lots of looking at the way the air flows over the fender is in order. I actually took the truck out in the rain and got it dirty. Did this so I can study the "dirt pattern" and how it flows over the fender. I'm no expert, but it looks like the flow may be in my favor. This was over the summer, so I must repeat this test again.
That just sounds soooo wrong. lol
