big problems
Old Mar 14, 2009 | 12:43 AM
  #61
BAdassR/T's Avatar
BAdassR/T
nope i have a second opinion goin there tomorrow.. hopefully things can get worked out... ive read alot of about them too and this wasnt like a spur of the moment thing.. i did alot of research on this pully and everyone said it was well worth it.... i dont see how this has anything to do with the chain it really doesnt..... ive had the pully for over a month and to be honest how the hell wouldnt it have broken it that month.. i did alot of test runs with it.. no problems then.. i think theres a screw loose in the dealers brain!
Old Mar 14, 2009 | 12:44 AM
  #62
Frenchy's Avatar
Frenchy
it is a wallet!
hahaha...
I shopped at Hot Topic once, bought an awesome linkin park t-shirt, and the guy goes, you want a frequent shopper card?
I was like, ooooook?
So I have two holes punched in it..
Old Mar 14, 2009 | 12:54 AM
  #63
BAdassR/T's Avatar
BAdassR/T
LOL wtf is it for? do u get like something free after spending a complete waste of time in the store?
Old Mar 14, 2009 | 01:32 AM
  #64
Frenchy's Avatar
Frenchy
i don't know, honestly... I think you get 15% off your order if you spend like, 100 dollars in the store...
I mainly only buy ae clothes... but I really needed to have that LP shirt...
Old Mar 14, 2009 | 11:34 AM
  #65
superdak05's Avatar
superdak05
the only thing i can think of, it was not mounted correctly, could have been off just a little to cause the damage
Old Mar 15, 2009 | 12:18 AM
  #66
curtiplas's Avatar
curtiplas
Originally Posted by shrpshtr325
lol hope its not, i mean that would mean frenchy is one of THOSE ppl and we dont want that to be true now do we ????
Hey now I'm one of those ppl... well not so much anymore but every once and a while I still go into Hot Topic..
Originally Posted by cramerica
Jeeez, one little shot of sarcasm gets everyone up in arms.
Don't worry French, you're still the man. Not in a general sense, just in the realm of an internet website devoted to a highly specific segment of the automotive world.
First off Frenchy's been taking some heat across the forum lately.. we gotta stick up for him, cuz everyone picks on him...
Second off, that's awesome :-P
Now about Badass's Dak, that blows, hopefully your second opinion works out, but you only had it on for a month before this happened? I mean if the UP was out of timing it could have worn on the crank until it broke, or it could have been knocked out of timing somehow and broke the crank when it did causing all the subsequent probs... Anyway Hopefully it all works out for you
Old Mar 16, 2009 | 12:47 PM
  #67
BAdassR/T's Avatar
BAdassR/T
heres the info i got from my buddy
quote
"Just got back from checking out Joe's truck @ the dealer and it's legit It seems that the crank bolt needs to be removed for the UD pulley to go on. No big deal, right. Here's the rub. The flange on the new pulley is thinner than the stock pulley. So, when the crank bolt was re-tightened, it bottomed in the crank without drawing the damper all the way down. As a result the pulley and damper have been wobbling on the end of the crank for about a month. The wobble busted the keyway out of the crank timing gear and blammo. The timing chain and top gear look to be fine. The bottom gear is hosed and the end of the crank was scored up a bit. The crank snout has been sanded down and looks to be ok now, but you can definitely tell it was chewed up a bit. My buddies @ the dealer are going to try and get a partial warranty/deductable deal approved for Joe. So, that he doesn't have to eat the whole cost. Moral of the story, UD pullies on the 4.7 are a nono, or at least, jam a couple of big washers under the crank bolt, before you tighten everything down. That will keep the bolt from bottoming before the damper is tight. I've always though that UD pullies were not worth the effort, due to the meager HP gains vs. the charging problems they can cause. Now here's another reason that they're a BS mod. It remains to be seen whether the valves hit the pistons, but the 4.7 is an interference motor. We'll know more on monday when they put it back together and try to start it. Hopefully things go in Joe's favor, and nothing hit. More to follow....."
now im getting asp involved they said they will pay for any damage to the truck if the there were missing parts... more to come on this situation!
Old Mar 16, 2009 | 02:27 PM
  #69
cramerica's Avatar
cramerica
Damn! So that UD pulley kit doesn't come with proper hardware? The fit must be awfully close, or else the pulley would be noticably loose when the bolt couldn't be turned any more.
And the 4.7 *is* an intereference design?
Old Mar 16, 2009 | 05:12 PM
  #70
Altair's Avatar
Altair
Dak attack!
Oh Damn!! That sucks! Looks like Gates was wrong about the 4.7 being a non-interference engine too... Real sorry to hear that man...
