Double Din Head Unit ?
Old 09-12-2010, 04:20 PM
ballsout's Avatar
ballsout
ballsout is offline
im currently doing this to my truck now and here is what is did...the bezel looks perfect and the deck looks factory.
take out the bezel, use a dremel to shave down enough for the deck to fit.
you have to cut the plastic underneath where the old deck was sitting on top, i used a dremel for this as well.
to fill the ear holes from the stock deck i epoxy'd some plastic tabs in behind them and lined them up with the edges where the deck goes.
now is where it gets messy and annoying, i used bondo to fill the ear holes and did about 5 coats to blend it perfectly and make it smooth and look like it was always one solid piece. I also bondo'd where i cut the bottom with the dremel because im **** and knew i would be annoyed if it wasn't perfecly smooth.
i then put glazing putty over all the bondo to fill any pin-holes or sanding marks.
i then primed the whole bezel with filler primer. i an color matching the bezel to the exterior colour of the truck so i got a rattle can of paint mixed to it, sprayed about 4-5 coats and am about to shoot my 4th layer of clear on it.
to mount the deck i used vent strapping and cut it into tabs so i could bend them to make the deck centered in the hole.
all in all this was about 6 hours of work and about 50 bucks in materials but it will look like it came from the factory with a double din.
i will post pics tomorow after everything is wired and mounted back in the truck!
Old 09-12-2010, 10:25 PM
JimBio's Avatar
JimBio
JimBio is offline
Does this only apply to the 05,06,07 models? Did they make the 08+ models double din friendly?
Old 09-12-2010, 11:10 PM
ballsout's Avatar
ballsout
ballsout is offline
i dont know for sure but i think 08 and up are 2 din friendly
Old 09-13-2010, 09:17 AM
dakota_raven's Avatar
dakota_raven
dakota_raven is offline
Originally Posted by biker_ahoy
Was looking at this unit and wondering if it would fit?
http://www.clarion.com/us/en/product...409024110.html
and the face plate do they make one to fit doubles?
I think that will be a perfect fall mod. "YOU CAN DO IT" But don't go paying $600.00 for that. Check this out!!
http://infiniteelectronix.com/clario...uchscreen.aspx
Quick Reply: Double Din Head Unit ?
