Alcohol Injection Complete
Old 05-11-2009 | 10:08 AM
superdak05's Avatar
superdak05
my convertor tends to hold first gear a little to long. if i get on it it stalls just great, but coming off a light in traffic, it tends to wanna creap up in rpms before it lurches into gear. and before i had issues with keep the tires planted. now forget it. i have such wheel hop it feels like the back end is going to break free from the rest of the truck. i may have to try a different type of drag radial at the track
  #33
Old 05-11-2009 | 10:10 PM
Blown287's Avatar
Blown287
I'm going to make a complete DIY for this. To include the injector flow calculators and injector pulse witdths.
So far I have tested the following mixtures.
1. 75% Ethanol 25% water
2. 100% Methanol
3. 100% Denatured Alcohol.
So far 3 has been the best at lowering EGTs and boosting HP in my truck. Right now I'm starting flow at 3psi boost and I think that is as low as I will go for now. I can program it for 1psi if I really wanted to, but so far 3psi seems to be the magic number.
  #34
Old 05-12-2009 | 07:52 AM
Racinartist's Avatar
Racinartist
There is an article in this month's PRI magazine about alcohol/water injection. Apparently it's becoming really popular for forced-induction engines.
  #35
Old 05-12-2009 | 02:37 PM
Blown287's Avatar
Blown287
Meth cooling systems are becomming more popular alternatives to intercoolers. I'm runnnig my Alcohol program to cool the blower charge and as a power fuel to aid in acceleration. I'm also adding a tank with alcohol line looped several times and putting dry ice in it to seriously drop the alcohol temp. We are calling it "Cryo Alky," lol.
  #36
Old 05-12-2009 | 05:10 PM
Racinartist
Damn, dropping the temp of the alcohol? Like it's not cold enough???? lol
From what I've been reading, the main purpose/benefit of injection is cooling of the intake temp on forced induction. Makes perfect sense to me.
  #37
Old 05-12-2009 | 07:26 PM
Blown287's Avatar
Blown287
What I'm contructing now is called a "Dry Ice Chamber." There is a small cylinder that I have spooled alcohol line into. It sits inside a larger cylinder and is insulsated by styrofoam. The small cylinder is packed with dry ice. It will mount inside the engine bay and be used for dyno and racing. Only a foot or so of travel to the injectors.
I'm not just cooling with it. Im' fueling with it also, similiar to nitrous systems. That is why I need all of the computer control. My compression ratios changed, my plenum pressure is effected, etc.
Ethanol (denatured alcohol) contains oxygen, it has a very low power stoichiometric when compared to gasoline fuels (6.5 compared to 12.5). Ethanol must be run at much richer mixtures than gasoline, more than offsetting the lower energy per unit volume. The net energy released per cycle is higher and this results in more horsepower.
For example, if gasoline is run at its preferred max power air fuel mixture of 12.5/1, it will release approximately 19,000 BTU's of energy, where ethanol run at its preferred power stoichiometric of 6.5/1 will release approximately 24,400 BTU's. By comparison, methanol releases slightly more, about 27,650 BTU's. The more ethanol there is in gasoline, the more powerful it is as a motor fuel."
http://www.drivingethanol.org/motors...teristics.aspx
  #38
Old 05-12-2009 | 07:44 PM
Blown287's Avatar
Blown287
Default This is my calculator
Variables (Fluid)
Plenum Pressure 11.00000 PSI
% Air/Fuel vs. Alcohol/Water 12.50000 % Mix
Engine RPM 500.00000 RPM
Timing Retard 10.00000 Deg BTDC
Engine Temp 180.00000 Deg F
Ambient Temp (Air Sensor) 75.00000 Deg F
% Alcohol Vs. Water (By Weight) 50.00000 % Alcohol
Fuel Inj Duty Cycle 85.00000 %(%*10 = Msec)
Pump Press 70.00000 PSI
Fuel vs. Air % 14.00000 % Fuel
Stats Value Unit
Max Fuel Inj Vol @100% Duty Cycle 403.53213 CC/Min (EA)
Max Alcohol Inj Vol @100% Duty Cycle 792.50721 CC/Min (EA)
Required Alcohol Inj Vol for % Mix 446.05660 CC/Min (TOT) 223.02830 CC/Min (EA)
CYL Volume (Not Compressed) 58.76250 CC
CYL Volume (Compressed)(Retard MOD) 6.05799 CC
CYL Pressure (Not Compressed) PSI (Absolute)
CYL Pressure (Compressed) PSI
Realtime Compression Ratio 31.96982 X:1
CYL Temp (Not Compressed) Deg F
CYL Temp (Compressed) Deg F
Air Volume (By Weight) 3225.45048 CC/CYL 25.80360384 CC/CST/CYL
Fuel Volume (By Weight) 343.00231 CC/MIN/CYL 2.744018468 CC/CST/CYL
Alcohol Volume (By Weight) 223.02830 CC/MIN/CYL 1.784226394 CC/CST/CYL
Water Volume (By Weight) 223.02830 CC/MIN/CYL 1.784226394 CC/CST/CYL
Variables (Static) Value Unit
Engine Displacement 4.70100 Liter
Number of Cyl 8.00000 EA
Stock Compression Ratio 9.70000 X:1
Engine Stroke Count 4.00000 EA
Fuel Rail Press 43.00000 PSI
Fuel Injector Press Rating 47.00000 PSI
Fuel Injector Flow Rating 441.07000 CC/Min
Alcohol Injector Pressure Rating 43.00000 PSI
Alcohol Injector Flow Rating 577.59000 CC/Min
Stock Idle Timing Retard 10.00000 Deg BTDC
Alcohol Vapor Density vs. Air 1.60000 X:1
Alcohol Flash Point 73.00000 Deg F
Alcohol Auto Ignt Temp 363.00000 Deg F
Alcohol Lower Expl Limit 3.30000 %
Alcohol Upper Expl Limit 19.00000 %
97 Oct Vapor Density vs. Air 2.07792 X:1
97 Oct Boiling Point -18.00000 Deg F
97 Oct Auto Ignt Temp 495.00000 Deg F
97 Oct Lower Expl Limit 1.40000 %
97 Oct Upper Expl Limit 7.60000 %
1 Lb of H2O 47.31760 CC
1 Lb of Air 264554.70000 CC
1 Lb of Fuel 630.12000 CC
1 Lb of Alcohol 485.19289 CC
Idle Vac Press -8.00000 PSI
Required Alcohol Inj Duty Cycle F MAX HP 28.14212 % 281.4211614 Msec
Calculator
Molecular weight calculator URL
  #39
Old 05-12-2009 | 08:07 PM
baracis's Avatar
baracis
i just threw up
  #40
Old 05-12-2009 | 08:09 PM
Blown287's Avatar
Blown287
Originally Posted by baracis
i just threw up
Why?..........
Quick Reply: Alcohol Injection Complete
