Alcohol Injection Complete
#51
Blown, I was taking a quick peek at your calculations post and there was something like the compressed volume of each cylinder was ~6cc and the water volume was like ~200ish cc per cylinder (or am I totally reading that wrong?)
Is there a danger you will reach a point where the water volume exceeds the compressed cylinder volume and "lock" your engine hard?
Thanks,
John
Thanks,
John
#52
For anyone else who wants the info, here is the sight that has all of the programs to complete all calculations for anything needed.
http://www.rbracing-rsr.com/calculations.htm
#54
Thanks,
John
Thanks,
John
Alcohol Volume (By Weight) 223.02830 CC/MIN/This is going into the throttle body
CYL 1.784226394 CC/CST/CYL this is CC Per Individual Cylinder.
Water Volume (By Weight) 223.02830 CC/MIN/Per all 8 Cylinders
CYL 1.784226394 CC/CST/CYL Per Individual Cylinder.
With this mixture, 250cc is the safest I can run. The calculations chage as I change mixtures.
#55
I finally found my camera.
Here is a pic of the PCM tap, injectors and relays.
All the good stuff.
The Alcohol tank and pump.
All the good stuff.
#57
#59
I already had the split second computer, wiring harness and relays.
$ # Used Item
25.00 (2) Bosch Top Fuel Alcohol Compatable Racing Injectors
68.00 (1) Northern adjustable water pump
15.00 (1) 15ft of Devils Own Alcohol Injection Tubing
10.00 (1) Chrysler Caravan windshield washer fluid bottle
15.00 (1) Various electrial wiring connections.
Me too, that is why I decided to go with Herculiner. I'm bad when it come to DIY.
$ # Used Item
