Track time
Old May 20, 2009 | 01:41 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Default Track time
Well, its been a few months since I have posted. I have been extremely busy trying to get the Talon ready for this season. We made 2 passes before we got rained out. These passes were purely to get some form of open loop tune. I turned the boost down as low as I could. These 2 passes were NOT meant to get the best time out of the car. Consider the following:
A/F ratio was 10.78:1 all the way down the track
ABSOLUTELY NO ADDITIONAL TIMING
15psi (instead of 25psi...which nets me around 420whp on 91 oct)
street tires@ 32psi (not drag radials)
no 2-step launches
disabled the lift-to-shift feature
didn't heat the tires at all
Basically, we did everything we could to slow the car down as much as possible. Also consider that my local track is Bandimere Speedway (elevation 5800ft...most cars loose about about 1.1 sec from sea level)
14.389 @ 110 mph
2.8XX 60ft. (spun through 1st and 2nd)
If you are not completely laughing at the ET vs trap vs 60ft, (and all of the above considerations) you haven't been drag racing long enough.
We made a few open loop pulls on the highway after that on 25psi. The car makes a stupid amount of power @ 11.5:1 A/F ratio. I would imagine that I would trap close to 120 on street tires. Next time at the track will be mid June with the drag radials, 25psi, and some what of a tune. We are pleased with these results considering all the above.
The Dak pulled the Talon, trailer, and all the tools just fine.
Old May 20, 2009 | 03:55 PM
BAdassR/T's Avatar
BAdassR/T
dam i thought u were postin about the dak but yeah ur 60 needs to come down drags are a must with that type of power.....
Old May 20, 2009 | 04:47 PM
Cuban11182's Avatar
Cuban11182
Is this the AWD version? I had a 1g GSX that I miss.
Old May 20, 2009 | 05:01 PM
donkeypunch
King Jackass
Nope, front wheel drive.
Badass, the street tires are 215/45/17s. I have a set of 275/40/17 Nitto 555 DRs that will go on for the next race.
Old May 20, 2009 | 08:26 PM
Blown287's Avatar
Blown287
Congrats man, 110 is still a good trap.
Old May 20, 2009 | 09:46 PM
baracis's Avatar
baracis
Can I have the talon?
Old May 20, 2009 | 09:47 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
You dont have the ***** to drive it little man
Old May 20, 2009 | 10:09 PM
baracis's Avatar
baracis
Gimme the keys and find out.
