Gauge Selection
Old May 27, 2009 | 12:18 PM
baracis's Avatar
baracis
Default Gauge Selection
In anticipation of the supercharger, I'm going to go ahead and start getting things ready. Here are the two gauges I have picked out for AFR ratio and boost.
http://www.glowshiftdirect.com/black...tio-gauge.aspx -- AFR
http://www.glowshiftdirect.com/black...uum-gauge.aspx -- Boost
I looked in the DF search engine for the write up somone did on making our own gauge pods. I'm going to find that and bump it. Could someone please put that in our 3rd gen dak FAQ section. Thanks!
Old May 27, 2009 | 12:26 PM
Blown287's Avatar
Blown287
That A/F gauge will not work. You need a wideband A/F gauge. The one you posted is a 1volt narrowband A/F that is good for a light show, that is about it.
This is the AEM A/F I'm using and its the cheapist I could find at the quality I needed. This one is 218 clams
http://cgi.ebay.com/ebaymotors/AEM-G...lenotsupported
Old May 27, 2009 | 12:27 PM
baracis's Avatar
baracis
Not enough voltage I take it?
Old May 27, 2009 | 12:29 PM
baracis's Avatar
baracis
So this one will work then?
http://www.glowshiftdirect.com/Black...uel-Gauge.aspx
Old May 27, 2009 | 12:36 PM
Blown287's Avatar
Blown287
The basic job of a narrow band is to let the computer know whether the vehicle was running at an ideal air/fuel ratio during idle.
Wide Band O2 Sensors where developed to monitor air/fuel ratio information under all circumstances like WOT. To do this, they broadened the voltage range in which feedback from the sensor was provided and making a linear scale that provided a fixed voltage that correlated to a specific air/fuel ratio.
Old May 27, 2009 | 12:37 PM
Blown287's Avatar
Blown287
Yep, and its cheaper than mine.
Old May 27, 2009 | 12:42 PM
baracis's Avatar
baracis
Sweet, good info, on both accounts. I'm the master of cheapness, Mr. Frugal if you will. I'm gonna find it cheaper than that.
Old May 27, 2009 | 06:03 PM
baracis's Avatar
baracis
I'm stuck between the pillar mount and the dash mount. I would preferhttp://www.glowshiftdirect.com/Universal-Triple-Gauge-Console-Dash-Pod-Dome-Lip.aspx if it were angled towards the driver on the inside only. I wonder if I could accomplish that with a dremel.
