Installing Aftermarket Head Unit?
Old Jun 1, 2009 | 01:25 PM
nola24's Avatar
nola24
Default Installing Aftermarket Head Unit?
So I want to buy a aftermarket head unit, probably from Crutchfield. I'm going to do it myself, and I was wondering if it's just plug and play, or will I have to edit the dash covering, since I noticed that the stock radio has the two "ears." I want it to look good. What have y'all done to make it look right? Thanks in advance for responses.
Old Jun 1, 2009 | 02:07 PM
baracis's Avatar
baracis
When you get the kit for the dakota, the ears and all that will be included in the pod. I do believe there is an extra wire-set to purchase, ours is weird somehow. But I believe you can wire it to your cigarette lighter and call it a day.
Old Jun 1, 2009 | 05:02 PM
biker_ahoy's Avatar
biker_ahoy
Default deck installed
Ya you just need the pod that will fill in all the ears and such
andthen a wiring harness to go with it, easy to hook it all up
I believe they make two Pod styles, one has the tray under the deck? and the other is below
here's a pic of my old deck installed
http://www.cardomain.com/ride/3195839/4
Old Jun 1, 2009 | 06:05 PM
nola24's Avatar
nola24
thanks alot, so crutchfield will include the pod?
Old Jun 1, 2009 | 06:16 PM
biker_ahoy's Avatar
biker_ahoy
double check when you get the deck it will be seperate if they carry it, Audio stores will either have one or be able to order one for ya
Old Jun 1, 2009 | 06:25 PM
baracis's Avatar
baracis
If I were you, I would not order from Crutchfield. It's WAY overpriced.
Old Jun 1, 2009 | 06:49 PM
baracis's Avatar
baracis
http://www.sonicelectronix.com/
http://www.cardiscountstereos.com/
Try one of those.
Old Jun 3, 2009 | 10:50 PM
James3's Avatar
James3
I am just a step ahead of you. Bought a new c.d. player and trying to install it. The wiring harness I got that is suppose to be for a 2005 dodge dakota isnt working. Check my thread (I am still waiting for a reply).
https://dodgeforum.com/forum/3rd-gen...ml#post1690499
