Help me!!!
Old Jul 22, 2009 | 09:33 PM
keachers's Avatar
keachers
Default Help me!!!
In about a month i will be driving from NY to TX. lately my truck has been overheating especially on hills with my AC on. is anyone else having this problem? the only mods i have are a k&n filter intake and dual magnaflows. what should i do??
Old Jul 22, 2009 | 10:50 PM
fieldmedic8404's Avatar
fieldmedic8404
check the cooling system and maybe flush it out
Old Jul 22, 2009 | 11:02 PM
baracis's Avatar
baracis
Definitely give that a whirl. Also check to make sure nothing is blocking your radiator, make sure none of your hoses are kinked, check out your water pump, make sure it's not leaking or anything. I believe when our thermostats fail, they do so in the open position, so unless it's barely opening, or stuck somehow, it shouldn't be that. Check it out anyways. Hopefully it's something small.
Old Jul 23, 2009 | 02:06 AM
baracis's Avatar
baracis
Thats why I put check it anyways, just in case.
Old Jul 23, 2009 | 02:19 AM
Blown287's Avatar
Blown287
Hey brother, it certainly can't hurt to check.
Old Jul 23, 2009 | 05:21 AM
keachers's Avatar
keachers
but it only happens when i run the ac, if the ac is off it runs normal
Old Jul 23, 2009 | 05:53 AM
Cuban11182's Avatar
Cuban11182
That just means there is more of a load on the engine. I would think if you tried to haul something it would do the same thing.
Old Jul 23, 2009 | 10:34 AM
Cuban11182's Avatar
Cuban11182
I would say flush the system and replace the stat to see if it works. If not that then I would think possible water pump issues
