WOT shifting?
#21
I thought that during WOT shifts the computer pulls timing or fuel or something to lessen the harshness of the shift? I remember reading something about that.
Anyway, ever since I got my Borla put on it the WOT 4-5 shift sounds like a long blatty fart and it's embarrasing. And I suspect it's the way the transmission shifts because the RPM's jump about 200 - 300 and hold there for about a second before going into 5th. And it's during that time when it sounds like the fart.
Get rid of the torque management and it should go away. Maybe.
On a stock 545RFE under wide open throttle and shifting, the TCM sends a request to the PCM to reduce engine power until the shift is complete. Once complete, the PCM resumes 100% engine power. The reduction in engine power is variable but can be up to 30%. This allows the manufacturer to produce a smaller/lighter/more efficient transmission that generates smoother shifts at the cost of performance.
#22
#23
Here is what my truck does. At 5 seconds into the video it 'burps' where the pressure just dumps out when switching into 2nd gear.
http://www.youtube.com/watch?v=CEIf9wXOhCA
#24
what is happening is a w.o.t. shifts the truck will lose some power when shifting, causing this terrible noise, i never exsperienced it with the stock system, because of the resonators, but now i have the same issue. i dont mind the noise. it is kinda hard to hear it when the truck shifts. the tire chirp takes away the noise, but that sound is what it is. also you should hear a hemi, when it does it. sounds like some shoot a horse
#25
#26
#27
