Ok, confused...
Frenchy, if you look where your tranny bolts together(the clutch housing and transmission case housing bolt together), there should be a plug a couple of inches in front of there on the bottom of the trans to drain it. The discription in the parts manual just says Plug, screw. Item #2 on page 237 of the parts manual, if you find it.
Baracis, that alldata is sweet man!
on
1 Post
If you go to Amsoil's website and look on the top right they have an application guide, they'll helpfully tell you what the capacities are in addition to what type of fluid you need:
CAPACITIES
Engine, with filter..........6.0 quarts[1]
Cooling System, Initial Fill..........16.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 42RLE Initial Fill..........4.0 quarts[2]
Automatic Transmission, 45RFE 2WD Initial Fill..........5.5 quarts[2]
Automatic Transmission, 45RFE 4WD Initial Fill..........6.6 quarts[2]
Automatic Transmission, Total Fill
4 speed 45RFE 4WD..........15.0 quarts
4 speed 45RFE 2WD..........15.0 quarts
4 speed 42RLE..........8.8 quarts
Manual Transmission, Getrag 238..........4.6 pints
Differential, C205F Front..........3.6 pints[3]
Differential, with 8.25 ring gear Rear..........4.2 pints[4]
Differential, with 9.25 ring gear Rear..........4.5 pints[5]
Transfer Case,NV233..........2.3 pints
Transfer Case,NV244..........2.7 pints
1. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all
gears. Check fluid level in NEUTRAL and add fluid
as needed.
3. Fill to level of fill plug.
4. Fill no higher then 1/4 inch below plug hole.
5. Fill no higher then 5/8 inch below plug hole.
TORQUES
Oil Drain Plug.....25 ft-lbs
Transfer case
Fill Plug.....15-25 ft-lbs
Drain Plug.....15-25 ft-lbs
Manual Transmission Getrag 238
Fill Plug.....37 ft-lbs
Drain Plug.....37 ft-lbs
as needed.
TORQUES
Transfer case
