Frenchy, I thought our pans had no drain. I could be wrong, but I think you have to lower the whole pan. I have been thinking of doing that as well and changing both filters in the tranny at the same time, so hope I am wrong.
Frenchy, if you look where your tranny bolts together(the clutch housing and transmission case housing bolt together), there should be a plug a couple of inches in front of there on the bottom of the trans to drain it. The discription in the parts manual just says Plug, screw. Item #2 on page 237 of the parts manual, if you find it.
