Is it possible to change factor dash trim?
Old Sep 6, 2009 | 08:02 PM
  #21
marker227's Avatar
marker227
I need someone to tell me how to install a double din in my 2005 Dakota.
I don't care what it takes. I want it to be clean and flush.
This person did a custom job... I wonder who I can go to for a job like that.
Old Sep 6, 2009 | 08:43 PM
  #22
Altair's Avatar
Altair
Dak attack!
Looks to me like they got a dash kit like ericemery has then cut the 'ears' off and glued them in place after cutting out to fit the HU. I cut mine to put the MyGIG in, all you will need is a dremel and a steady hand (if you have a scroll-saw it will be even easier). Mark out your line well and remember measure twice cut once!
Old Sep 6, 2009 | 09:54 PM
  #23
marker227's Avatar
marker227
Is it possible to get a bezzel without the ears? Or instead of black plastic covers something that matches the grey dash?
Old Sep 6, 2009 | 10:32 PM
  #25
marker227's Avatar
marker227
I think the first idea you said sounds easiest.
Are you saying I just need to buy a dash kit and a local shop can work the rest of the details out?
Is this the right one?
Has ears
http://www.amazon.com/Stereo-Install.../dp/B000KKXO8K
No ears / double din
http://www.hifisoundconnection.com/S...id/0/SFV/30046
Old Sep 7, 2009 | 12:06 AM
  #27
marker227's Avatar
marker227
http://www.stinsonvoyager.com/Mygig%20Upgrade.htm
I'll do it like this guy did .
Old Sep 8, 2009 | 08:35 PM
  #28
marker227's Avatar
marker227
I'm still trying to figure out where I can buy a bezel that does not have the volume **** cut outs.. Dodge didn't do a good job giving me info on a bezel and I can't find anything online....
Can someone tell me where to go?
Old Sep 8, 2009 | 08:50 PM
  #29
Altair's Avatar
Altair
Dak attack!
The one difference there is the MyGig is wider than your standard double DIN and requires enough cutting that the ears become a non-issue. That said doing the cutting is not all that hard, I was one of the pre-orders for that lockpick adapter he refers to
Old Sep 8, 2009 | 09:02 PM
  #30
marker227's Avatar
marker227
I've changed my mind.. All I want to do is now order a factory gray bezel without the volume **** cuts and give it to my mechanic so he can install the radio..
Where do I get a bezel? Dodge was horrible at giving me info on one.. Couldn't even give me a picture or tell me what color I was ordering... He said there were 3 different kinds... Only price was listed... 140, 170, and 300. There was absolutely no additional info he could give me on it...
