Spark Plug Info!!!
Old Sep 23, 2009 | 01:58 AM
Mahadigus's Avatar
Mahadigus
Originally Posted by studlyblueiz
I don't know if platinum plugs are crap in our engine since mine came with platinum on one side of the engine...but I do know that the 3923s haven't performed any better than the stock ones and could be performing worse.
Since I've put them in the truck will cut off on cold starts. I'm not ready to place the blame on the 3923 plug but I will try a different plug next time.
this is due to you using the wrong plug in the ho. you need to run a heat range colder and that is the 3922's...I put the 3923's in and my truck pinged like crazy within the first 5min so I went back to work, did a little more research and found out that I had the wrong plugs...Installed the 3922's, reset my adaptive memory and the truck ran like a gem....i swapped to the ngk Iridium's and for the money I'd go with the 3922's again.
Old Sep 23, 2009 | 10:01 PM
studlyblueiz's Avatar
studlyblueiz
Originally Posted by Frenchy
only on one side?
what was on the other?
were they at least the same brand?
yep, copper was on the other and they were all champions.
Here's the post I started about it a year ago (almost to the day!)
Originally Posted by mprohr
I don't know if you have the HO or not.
HO motors dont like Platinum, or Autolite 3923.
HO motors do like Autolite 3922 or Iridium plugs. I have NGK Iridium X plugs. They do well.
I would like for someone to try the E3 Diamondfire plugs.....how bout you?
Yep, it's in my signature. Everyone keeps saying that but mine came with'em and no issues before...plus i looked up the spark plug # listed under my hood it is the 3340 Champion Single Platinum Spark Plug. Part# RC7PYCB4 Kinda odd dodge recommended a platinum if it didn't like it...
I'm hopin to try the E3's next. They're used all over HP tv.
Well the 3923s work fine for me at first...and may still. The truck dying could be something else...Just spent my savings for tires so I'll change plugs later to find out. Also, I think the 3923s were listed as the right plug at the time...
Old Sep 29, 2009 | 12:42 PM
canadian dakota's Avatar
canadian dakota
I've been reading up on the spark plugs and it seems you all prefer the autolites. I was looking at ngk. but im curious bout the e3's any one got any info on them
Old Oct 17, 2009 | 11:13 PM
King4x4's Avatar
King4x4
what NGK plug should i get?
thanks
Old Oct 18, 2009 | 09:18 PM
thecause17's Avatar
thecause17
What is wrong with the stock champions? Mine is due for its first plug change, and I had planned to just have the dealer do it.
How much of a job is the change with these trucks? I'm unfamiliar with this engine. My last truck (F-150) had coil on plug ignition and I ended up having to take the fuel rails out and everything to do them. If it's an easy change with the the 4.7L then I would just do it myself and keep my receipts like I do for everything else.
Old Oct 18, 2009 | 11:12 PM
popsnbeer's Avatar
popsnbeer
Well this thread made me go out and buy new plugs for my truck. I got the autolite 3922's per everyone's recommendations (on the 4.7HO). I was happy the truck started on the first crank! (usually I screw something up).
It took my about 90 minutes on the dot after a beer (or two) and a few curses from some knuckle pain hitting the engine! All in all, I only needed to move the air intake in order to get to 2 of the plugs. Not too bad, but damn those things sure are deep! I am glad I have an eclectic variety of extensions or else I may have had a harder time.
Ill let you all know about gas MPG and idleing. So far the idle seems a little more stable...but it could just be me :dunno: I did have a question though. Should I unplug the battery for a few minutes to let the computer reset in order to adapt to the new plugs? I have no idea about that stuff. Thanks!
Old Oct 19, 2009 | 11:26 PM
Z-809's Avatar
Z-809
Go with the BOSCH 4508
Old Oct 20, 2009 | 09:42 AM
popsnbeer's Avatar
popsnbeer
i almost went with the bosch, but I figured I would try the autolites first (considering they were a few dollars cheaper per plug.
Old Oct 21, 2009 | 12:17 AM
King4x4's Avatar
King4x4
Go with the BOSCH 4508? h.o or non h.o?
Old Oct 21, 2009 | 12:59 PM
Z-809's Avatar
Z-809
I have a 2007 4.7 Flex fuel non H0 and runs perfect with Bosch
My friend has 2006 4.7 H0 and runs perfect with Bosch
