Spark Plug Info!!!
Old Oct 22, 2009 | 03:43 AM
  #21
aznoble's Avatar
aznoble
i was thinking about trying the pulstar plugs I hear they work better
Old Oct 22, 2009 | 03:47 AM
  #22
aznoble's Avatar
aznoble
how do you reset the ecm or whatever it is. someone said unplug the battery??? for how long.
Old Oct 22, 2009 | 07:30 AM
  #23
bain64's Avatar
bain64
I've read 20 minutes.
Someone also posted the shortcut was to unplug the negative battery cable, and then turn the ignition to START and hold it for 5 seconds, which will drain the computer's power.
Old Oct 22, 2009 | 09:21 AM
  #24
popsnbeer's Avatar
popsnbeer
Do we need to reset the ECM after the new plugs are installed?
Old Oct 26, 2009 | 10:11 PM
  #25
markbomgardner's Avatar
markbomgardner
i tried the the autolite XPs and the Bosch Irridium and both caused all sorts of sensors to go off causing the truck to run like crap. The dealer said only to put the NGK's back in. I have 3.7L though..
Old Nov 19, 2009 | 11:08 PM
  #26
dakoduh's Avatar
dakoduh
I recently put the bosches in my 06 HO, the ones with 2 electrodes. Decided I should change them after checking in the manual & it said change at 30000 miles. The original plugs still looked like new though at 46000. The little thing for looking up parts at walmart only listed the bosches so that's what I got. Truck's been running exactly the same for 600 miles or so now...
Old Jan 11, 2010 | 03:55 PM
  #27
babygotdak's Avatar
babygotdak
Hummmm... It seems I am a bit behind on this one.
I have 97000 miles on my 05 with stock plugs. I was going with the "ain't broke, don't fix it mentality".
Would new polugs be good for the ole gal? If so are we still saying the autolite 3923 is the best? What gap?
Thanks.
Old Jan 11, 2010 | 04:26 PM
  #28
bain64's Avatar
bain64
Holy crap you have 100k on stock plugs. Yes new plugs will help. Get the 3923 .040" if i remember correctly.
Copper plugs were not made to last this long.
Old Jan 11, 2010 | 04:35 PM
  #29
babygotdak's Avatar
babygotdak
I had 96000 on my front brakes as well... with meat still on the pads.
Old Jan 11, 2010 | 05:21 PM
  #30
Slick Dakota's Avatar
Slick Dakota
[QUOTEI would like for someone to try the E3 Diamondfire plugs.....how bout you?[/QUOTE]
I am going to this summer after watching power block this weekend and the brought in a company to prove there results on how these plugs work so much better then the leading plug, here is there results.. They said there is also a write up on this some where on power blocks website, I never would have believed it but its worth a shot.. Cya Slick
