Power Windows
Old Oct 7, 2009 | 12:51 PM
Raytraci's Avatar
Raytraci
Unhappy Power Windows
2005 Dodge Dakota
Manuel says power windows should operate for 10 minutes after truck turned off this is not the case with my truck the Manuel also says the deal is able to turn this on but unfortunately my dealer is at wits end on how to do this does anyone have any ideas.
thanks for your thoughts.
Ray
Old Oct 7, 2009 | 12:56 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Are you keeping the doors closed? Cause if you open the doors after turning the ignition switch off it will deplete this power source until you turn it back on.
Old Oct 7, 2009 | 01:05 PM
Raytraci's Avatar
Raytraci
lightngblt02 thanks for your reply yes I am keeping the doors closed I think the dealer needs to turn this on some how.
Ray
Old Oct 7, 2009 | 03:08 PM
dakotaff's Avatar
dakotaff
My 2006 Dakota does the same thing. Also the radio will not operate after shutting the truck off.
Old Oct 7, 2009 | 03:19 PM
Cuban11182's Avatar
Cuban11182
Originally Posted by dakotaff
my 2006 dakota does the same thing. Also the radio will not operate after shutting the truck off.
ditto
Old Oct 7, 2009 | 03:51 PM
lghtngblt02
Maybe its only an 07 option? Mine stays on until the doors open, radio and windows!
Old Oct 7, 2009 | 04:18 PM
dakotaff's Avatar
dakotaff
Just took out the owner's manual for 2006, it says that the windows will operate only when the ignition switch is turned to the ON position. As for the radio, the ignition switch must be in the ON or ACC position to operate the radio. I would be surprised if 05 is different. So be it...
Old Oct 7, 2009 | 04:51 PM
Frenchy's Avatar
Frenchy
damn I like your truck!
Old Oct 7, 2009 | 05:14 PM
paul05dak's Avatar
paul05dak
have a 05 Dakota and the windows do not work once turned off. same thing for the radio. My 05 caravan does... who figure?!?
Old Oct 7, 2009 | 05:37 PM
dakotaff's Avatar
dakotaff
The 05 Durango's work too. Guess we are the Red headed stepchildren.
Thanks Frenchy...
