Brake Controller
If you don't have the tow package, there will be no plug and no way to use a brake controller. You're gonna need a tow package wiring harness, and I believe they are about $180 from the dealer. Installation is more than a little tricky as well, but doable. Gives you the blue plug, 7 pin wiring for the hitch, and all the doodads to interface with the fuse box, brake switch, and turn signals.
I installed the OEM Hitch and harness a while ago...there was *no* blue plug with the wiring harness when I bought it from the dealer...it does have the 7 & 4 pin connector, and all the electrical works fine (brakes, blinkers, etc...)
I just ordered the controller and an 'installation kit' (probably would have been cheaper to just get all the parts myself, but I need to get this done ASAP and don't have time to run around to all the stores)...Two wires to the battery, postive through a fuse, one to the brake pedal and the other to the blue wire from the tow harness...
thanks..
thanks..
Here ya go...6x10 trailer. Wiring up the brake controller was rather easy. The 'installation kit' from etrailers was ok, but you could have easily gone to any autoparts store to get the pieces you may need (I just didn't have the time).
Again, my truck did not come with the tow package...I installed the OEM Hitch and OEM trailer wiring harness. Which is nice, but if you are gonna run a 7 pin connector, there is no plug under the dash to connect the brake controller. Just 4 wires to hook up, battery pos, a relay, battery neg, blue wire from harness, and one of the brake wires.
nice. i like the black trailer w/ the black truck. Now, pardon me if this is a stupid question, but if I have the 7-pin connector on my OEM hitch and i plug that in from the trailer I use...wouldn't the brakes engage through that? my question is, why is a brake controller necessary?
I realize this might be stupid, but I have never had to use a brake controller before :-)
Enjoy your camper trailer!
