Brake Controller
I will soon be purchasing a brake controller for the truck. I have previously bought and installed the OEM Hitch and wiring harness...
I've looked on several sites and all controllers seem to plug into a blue socket up by the emergency brake...I have no such creature.
Is there a seperate wiring harness I need to be able to plug in the brake controller, and if so, what is the p/n and where can I get it?
thanks!
thanks!
Yep, that's the part # I have for what came with my truck. I found it under the rear seats when I first bought the truck. Its a blue wire harness and the instuctions say that there is a mating blue connector located under the instrument panel, left of the steering column, near the top of the large connector bracket. I apologize for the delay in getting the p/n for you, life got in the way.
No problem...I know how that goes!!
Thanks for the info, but that is not what I need...I don't have the blue mating plug under the instrument panel...
So....without the plug under the panel up by the emergency brake...how do you hook up the brake controller?
Anyone? thanks!
Anyone? thanks!
http://www.etrailer.com/tv-brake-con...e-durango.aspx
The vid is for a Durango, but from what I understand they are in the same place...near the end of the video they show the plug...it is on a bracket up near behind the emergency brake...
Trending Topics
