Question to ask....
Old Jan 6, 2010 | 01:50 PM
  #21
BLUEKOTA985's Avatar
BLUEKOTA985
Originally Posted by 05dakota4x4
Well i actually got mine through my work it the trailmaster 1.5" it wasnt to bad to install its the one that u actually have to take the strut apart and put new longer mounting bolts in do u want my works number to c how much i can get it for??
I think a 2" would probably be what I need to make the front even with the back so i could fit, a 30x10 tire? Cuz I did some measure ments i have 30x9 and the new tire will be 30x10...so i am trying to juggle everything around so my sh*t will be right.
Old Jan 6, 2010 | 01:56 PM
  #22
05dakota4x4's Avatar
05dakota4x4
i can get the other leveling kits as well i know rough country makes a 2.5" front and 1.5" rear block they say its for 2wd only though
Old Jan 6, 2010 | 01:57 PM
  #23
dakotaff's Avatar
dakotaff
I have the Trailmaster 1.5 leveling kit, and it is level.
Old Jan 6, 2010 | 04:27 PM
  #24
dakotaff's Avatar
dakotaff
Originally Posted by Slick Dakota
I am going to go with a wheel with "0" offset with a over all tire diameter of 31.61 .. Cya Slick
Hey Slick,
Just wondering what tire and size you're planning on?
Old Jan 6, 2010 | 11:22 PM
  #25
MrCrash's Avatar
MrCrash
Now crash another member here has a overall tire diameter of 275/65/18 with a stock wheel offset of +38 which puts him at 32.07 and he had major rubbing issues and had to do trimming to get them to run so I figure if you can stay under 32 you may be fine.
I wouldn't call it major rubbing. I took about a half inch off the inside edges of the splash guard and bumper to clear, and it rubs slightly on the fender liner at full lock. Not bad at all
Old Jan 7, 2010 | 01:02 AM
  #26
Slick Dakota's Avatar
Slick Dakota
Originally Posted by dakotaff
Hey Slick,
I am going to drop down in wheel size to a 17" wheel, I will post which wheel after there installed since no one else is running it right now.. I am going to run a Goodyear wrangler dura track 265/70/17 load ratting is a "C" and it's
1.09 bigger in overall diameter then my stock set up.. If I run into any rubbing because of the "0" offset of the new wheel, I will switch to BFG all terrain T/A 265/65/17 load ratting E which I am not to fond of because of our light Dakotas.. The bfg tire is the same overall diameter as my stock set up, I may change my secondary tire option but I got tired of looking for the moment and need a break from it all.. Cya Slick
PS..I am a big fan of white lettering tires so I leaned towards that when ever possible, maybe me being old school but I just like white lettering LOL.. By the way I like the good years because there not loud on the freeway even tho they look like they should be with there aggressive side wall pattern..
Old Jan 7, 2010 | 01:07 AM
  #27
Slick Dakota
I just don't wanna have to pull out the saws all LOL.. Cya Slick
Old Jan 7, 2010 | 01:11 AM
  #28
MrCrash's Avatar
MrCrash
30 seconds at each corner with a Dremel had me all set. Unless you are looking for it, you can't even tell where I trimmed
Old Jan 7, 2010 | 01:36 AM
  #29
Slick Dakota
Time for wheels Crash .. Cya Slick
Old Jan 7, 2010 | 03:42 AM
  #30
Blown287's Avatar
Blown287
I have Nitto 420S in 265 50 20 and no rubbing.
