Question to ask....
Old Jan 4, 2010 | 05:35 PM
BLUEKOTA985's Avatar
BLUEKOTA985
Default Question to ask....
Hello world...I am new to Dodge Forum. Was wondering, if anyone had pics of their Dak with 20's on it, cuz I am thinking of comming from the all terrian look on stock wheels to some 20's with an all terrian. I still have the 265/70/17 BFG All Terrian tires (30.5'') on my truck they are about 2 and half years old, yeah they LAST. Any pics posted on the thread would be appreciated.
This is my Idea: 20" 2 Crave No.4 SUV on a set of 285/50r20 Toyo Open Country A/T
WHEEL:
http://www.hpautoworks.com/images/2crave4.jpg
TIRE:
http://eastcoasttires.com/store/pc/c...AT%20(300).jpg
Thanks,
T
Old Jan 4, 2010 | 06:51 PM
dakotaff's Avatar
dakotaff
Welcome to the site. There are members running 20" wheels around the forum, & I will be one of them after winter. But I remember one had 285/50/20 tires and they would rub, how bad I'm not really sure. He switched them out for 265/50/20's, which a few guys have that size. Looking through the tire threads myself, my opinion is not to go wider than the 265's.
Post up a pic when you've got em on.
Old Jan 4, 2010 | 07:24 PM
BLUEKOTA985
Yeah, that's the thing, I am trying to find a number tire to match the size tire i have now (30.5) tire, thats damn near the biggest i can go. When i first got the tires it rubbed a little in the front when you would turn and it would rub the inner part of the guard for a sec but wasn't bad at all. So 265/50r20 is equal to a (30.5) tire? Basically I am trying to find an all terrian that is the same size as i have now but for 20's. I tried searching 265/50r20 in the Toyo Open Country A/T; but no luck.
T
Old Jan 4, 2010 | 07:54 PM
dakotaff's Avatar
dakotaff
I'm was also searching for an aggressive tire, plenty of looking on my part. What I found in a 265/50/20 size is Nitto Terra Grappler. Right now that is what I plan on getting, specs on it are 30.51 diameter, 10.75 wide. Tire looks great & gets great reviews.
Old Jan 4, 2010 | 08:01 PM
BLUEKOTA985
Yea, Those look good too. I heard good things and bad things about them. But every person has different taste, ya know. I got a few friends with the Toyo Open Country A/T on 22's and 20's. They love em. The guy with the 22's Dad owns a tire shop and he recommended the Toyo's to me. I did some searching. The Cooper Zeon Ltz doesn't look like a bad tire either. Don't know the reviews on it but it's a good looking tire.
Old Jan 4, 2010 | 08:11 PM
dakotaff's Avatar
dakotaff
Yeah, looked into Cooper Zeon LTZ, I like them also, but they are too big. The smallest sizes were 275/55/20 (31.9x11.2) or 285/50/20 (31.3x11.6) . I don't want to get them & have them rub. I'm worried about the tire width. If you want to be the guinea pig, it's ok with me.
Old Jan 5, 2010 | 02:25 AM
Slick Dakota's Avatar
Slick Dakota
Here is a members truck that I saved in case I wanted to go that rout with running 20" wheels..
Old Jan 5, 2010 | 02:53 AM
Slick Dakota
265 is the widest I think you should go by every thing I have read also, unless your going with that nice short sidewall height like Eric is doing, but you should be able to go all the way to a over all tire diameter of 31.65 on your tire rim combo with out rubbing.. Q-tip is running this only with a smaller wheel and larger tire with a stock wheel with a +25 offset.. As your offset changes on your wheel you have to watch rubbing issues, Now crash another member here has a overall tire diameter of 275/65/18 with a stock wheel offset of +38 which puts him at 32.07 and he had major rubbing issues and had to do trimming to get them to run so I figure if you can stay under 32 you may be fine..
Do not forget that both of the trucks I listed above have had 2" leveling kit on the front and 2" blocks on the back.. I am going to go with a wheel with "0" offset with a over all tire diameter of 31.61 which hopefully with that off set will make it with out rubbing issues I hope.. I am not going to get them till spring since I don't want to run them in the snow with all this salt, good luck.. Cya Slick
Old Jan 5, 2010 | 03:04 AM
Slick Dakota
Originally Posted by ericemery
toyo makes great tires... I am going to be putting some new proxes in 275/45/20 with tax money.
either that or nitto's,
Wow with that tire size Eric your 3/4" smaller in overall diameter then my stock 18" wheel..Cya Slick
