need offroad advice
Old Jan 15, 2012 | 12:49 AM
  #41
Frankiejaime88's Avatar
Frankiejaime88
About what dakkkota???
Old Jan 15, 2012 | 12:56 AM
  #42
Frankiejaime88
Old Jan 15, 2012 | 01:08 AM
  #43
Dakkkota's Avatar
Dakkkota
just go with WWW.JACKMYRIDE.com????
Old Jan 15, 2012 | 01:11 AM
  #44
InnerCityHillBilly's Avatar
InnerCityHillBilly
If it where me i would use a add-a-leaf for the rear rather then a block. Its just adding a leaf spring with a bigger arch and will fit right into the factory leafs. just find out what width your leafs are. Summitracing.com sells them for $80 for a set of 2 and im pretty sure they come with new U bolts but i think you might have to find a longer center bolt to fit. It will probably give you2 or so inches of lift in the rear and will give you a little bit better bed capacity. And if you want to look at a good Solid Axle Swap look at the 1st gen section, there are a couple of guys that have very detailed threads about what the swapped and how they did it. it will need custom work and fab but it seems like it be worth it, all you need is the money and the time haha. Just my 2 cents
Old Jan 15, 2012 | 01:52 AM
  #45
Frankiejaime88
I like knowing Exactly what I'm buying prior, I don't like the fact they don't show any of the components before installation. Plus the shipping from az to Ak has got to be crazy
Old Jan 15, 2012 | 02:11 AM
  #46
marcsnyder05's Avatar
marcsnyder05
Originally Posted by Frankiejaime88
Is that your dak?
Ya it's pretty sweet looking just expensive
What kind of filter did you use for your intake
The one made for the 04 model went on without an issue
No I wish that one was mine. Its an 08+. I used a specter filter.
Old Jan 15, 2012 | 02:25 AM
  #47
Dakkkota's Avatar
Dakkkota
add a leaf is junk because it ride way to stiff. Deaver leaf is a better choice.
longer leaf 64''GMC sierra with relocated front mounting with long shackles 7'' is the way to go.
front SAS is alot of trouble to find the right parts..an alot of custom fabrication.
JMR is the easy way to go and keep stock wheel bolt patern.
Old Jan 15, 2012 | 02:46 AM
  #48
FrenicX's Avatar
FrenicX
The guys at JMR are offering free shipping to help get their name out. I'm not sure why they aren't showing the full kit pictures, but my guess is it's a business move. They are the first (unless those alaska guys start kicking some out) to have a kit, if they let everyone and their dogs see the ins-and-outs of the product, someone with more resources may take it and copy. I bet you could email them to ask for pics. They also have other pics here on the forums if you find the thread made by DesertRat
Old Jan 15, 2012 | 03:15 AM
  #49
Frankiejaime88
I might consider it depending on how much travel it'll have
Old Jan 15, 2012 | 11:24 AM
  #50
Dakkkota's Avatar
Dakkkota
what alaska kit?
