Is this a common problem
Old Jan 28, 2010 | 04:58 PM
sprice13126's Avatar
sprice13126
Default Is this a common problem
I have 05 dakota with under 75,000 miles. I have to replace the exshaust manifold. Are they a common thing that goes?
Old Jan 28, 2010 | 05:03 PM
canadiandodge's Avatar
canadiandodge
i personally havent heard of that but other might chime in. if you have to replace it, it might be a good idea to put a performance one on.
Old Jan 28, 2010 | 05:53 PM
hwcurtice's Avatar
hwcurtice
You didn't mention what engine this is. There could be a difference between the 3.7, the 4.7, the 4.7 HO....
Old Jan 28, 2010 | 05:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
Its common for the rear exhaust studs to snap off and causing it to leak exhaust. The manifold have not been a problem. Did you have the dealer replace under warranty? The reason i ask, in california there is a 8/80 emission warranty and that would be covered . There is an updated exhaust gasket that is thicker than the factory. That make up for warpage,
Old Jan 28, 2010 | 07:22 PM
mprohr's Avatar
mprohr
Master tech is right on. Busted manifold bolts are a common problem. A cracked manifold is not as common, but it does happen. Are you possibly confusing a bolt and gasket replacement for a manifold replacement?
Old Jan 28, 2010 | 08:09 PM
sprice13126
The engine is a 4.7, the dealer said that it was the manifold. No warranty to fall back on for this repair.
Old Jan 28, 2010 | 10:51 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
What did they say was wrong with it?
Old Feb 1, 2010 | 12:57 AM
sprice13126
Got the truck out of the shop and found out that it was just bolten bolts and a bad gasket. Thanks for all the help.
Old Feb 1, 2010 | 01:38 PM
rainier's Avatar
rainier
I have an 05 4.7 and have a cracked manifold. But the dealer claims it is covered under the federal emissions warranty (7 year/70k) and is replacing it for me.
