Another gears ?
Old Mar 7, 2010 | 02:11 AM
  #41
hendrixx324's Avatar
hendrixx324
Originally Posted by Blown287
Front and back gears must be the same if you have a 4x4. If you decide on 4.10s, you will have to do both front and back if you plan on still being able to use 4x4.
What i meant was if i just put the gearz from the 02 diff in my front diff. and dont switch out the back and then make them 4.10 gearing would that work. If that makes sence
Old Mar 7, 2010 | 02:18 AM
  #42
trucky's Avatar
trucky
No, you get front and back aftermarket 4.10 gears from Randys ring and pinion, on that website there are gears for the 8" fronts and the 9.25 rear. All you need from the 02 diff. is the HOUSING, not the gears inside it. those won't be 4.10 anyway. see?
Old Mar 7, 2010 | 02:22 AM
  #43
hendrixx324
Ohh ok i see. hahah im still learning this stuff. Thanx!
Old Mar 7, 2010 | 11:07 AM
  #44
thecause17's Avatar
thecause17
Originally Posted by trucky
thecause- No, I tried to explain it but it's weird. Reverse rotation has nothing to do with motion, it's all the same direction for parts. The word rotation throws people off. It is only referring to the direction of the spiral inside the housing, instead of a clockwise spiral, it's counter. It supposedly makes the axle stronger due to wear the ring sits. Otherwise it is just a PIA for us.
Ok, I understand what you're saying. I wasn't sure that if the spiral changed the shaft would too...thanks for clarifying.
Old Mar 7, 2010 | 11:38 AM
  #45
Dinger838's Avatar
Dinger838
this really throws a wrench in my plans. so the gearing on a 4x4 is basically impossible to do from what im reading. since we cant do 4.10s without junk yard parts is it worth it to throw the 3.92s in? and the ram does not use our reverse rotation or something correct?
Old Mar 7, 2010 | 01:44 PM
  #46
Altair's Avatar
Altair
Dak attack!
Trucky are you sure the Ram doesn't use the same reverse rotation? Economically it doesn't make sense for them to switch the Dakota and not the Ram, the more parts they can manufacture in common the more cost savings they get through economies of scale.
Old Mar 7, 2010 | 05:22 PM
  #47
Dinger838's Avatar
Dinger838
That is exactly what i was thinking. The more parts they can reuse the more money they save. I hope the ram gears somehow work i was hoping the 4.10's would be the awnser to v6 blues
Old Mar 7, 2010 | 08:22 PM
  #48
trucky's Avatar
trucky
The guy I called asked that for me I believe, I really don't have an answer right now. I would think out of all the companies I contacted about my problem would have mentioned it if it were that easy. I will call him back tomorrow and ask, as well as post on the ram section. We will clear this up, but don't rasie your hopes because SuperDak05 has front and rear gears only because he got a custom job.
Old Mar 7, 2010 | 08:58 PM
  #49
Altair's Avatar
Altair
Dak attack!
From what I've been able to find the 4.7l Rams use the same C205F front axle we do, just can't seem to find any info on whether they have that reverse rotation or not too.
Old Mar 7, 2010 | 09:28 PM
  #50
Dinger838's Avatar
Dinger838
I'll keep my finger crossed.
