Another gears ?
Old Mar 8, 2010 | 01:51 PM
  #51
sleds's Avatar
sleds
Thanks for doing all of the leg work on this one Trucky. I have thought of doing the upgrade to 4.10's as well and this has been a very interesting read. It seems like Dodge couldn't have screwed our trucks up more if they tried as far as aftermarket support. I love my truck, but this is crazy.
Old Mar 8, 2010 | 08:08 PM
  #52
trucky's Avatar
trucky
Working on it in the Ram forum right now, with the help of Emery too. We will get to the bottom of this.
Old Mar 8, 2010 | 09:50 PM
  #53
canadiandodge's Avatar
canadiandodge
good i will also try and hit up a local shop this week i found another that might know a little more
Old Mar 9, 2010 | 02:57 PM
  #54
trucky's Avatar
trucky
Yes let us know!
Old Mar 9, 2010 | 03:49 PM
  #55
canadiandodge
lol sorry i just found a small shop that all they do is gears just gotta find a second
Old May 24, 2010 | 03:48 PM
  #56
carlock's Avatar
carlock
Guessing you guys gave up on the gears? I was hoping you would find something, Thanks for looking/ posting all the info
Old May 24, 2010 | 08:23 PM
  #57
trucky's Avatar
trucky
End result is you have to either get a fabbed up gearset like superdak, or use the front axle off an 02-03 durango that you find in a junkyard, and put the aftermarket gears inside that. Overall not worth it in my opinion unless you stumble on a cheap used front axle.
Old May 24, 2010 | 09:31 PM
  #58
Dinger838's Avatar
Dinger838
Originally Posted by canadiandodge
well thanks trav now my one question would it be worth going from 3.55 to 3.92 or make the 4.10 work
X2 This is my question as well
Old May 25, 2010 | 12:28 AM
  #59
canadian dakota's Avatar
canadian dakota
did the durango come with 4.10 and was it ifs or solid axel
Old May 25, 2010 | 08:52 AM
  #60
trucky's Avatar
trucky
It doesn't come with 4.10 that's why I mentioned you have to get the axle AND drop in aftermarket (4.10) gears. I also thought I answered that 3.92 or 4.10 question already, I said it would not be worth all that money to upgrade to a stock gear ratio that is only 1 step above the lower (3.55) ratio. 4.10 or even 4.56 are the only way you are going to get your money's worth.
Let's not forget we are only talking about 4X4's with this problem. If you have 2X4 you can get 4.10 for the rear and they WILL fit no problem, just get the correct axle size (9.25 I believe).
As far as ISF or Solid I don't know for Durango...ask on the Durango forum?
