20x9 SRT10 WHEELS WITH 285/50/20 COOPER ZEON LTZ
Old Apr 22, 2012 | 10:33 AM
  #41
BAdassR/T's Avatar
BAdassR/T
I rub with 275-50-20 with a body lift I did not trim anything tho. Your gonna have problems
Old Apr 22, 2012 | 12:33 PM
  #42
onesikeuro's Avatar
onesikeuro
ok i hear you. What all did you have to trim in order to fit yours?
Old Apr 22, 2012 | 12:38 PM
  #43
onesikeuro's Avatar
onesikeuro
any advice from you guys that are running 20's? As far as tires and best way to adjust heighth?
Old Apr 22, 2012 | 01:13 PM
  #44
kbond's Avatar
kbond
i absolutely love the srt10 rims!
Old Apr 22, 2012 | 01:24 PM
  #45
FrenicX's Avatar
FrenicX
Best way to get height is the leveling kit, 2" will do. As for trimming, for 55 series... that's gonna be a lot. And even more or less depending on the offset of the 20s.
I was at stock height, with stock diameter tires, and a +13 offset (barely more than perfect, being +19) and still had to trim the inner mudflap lip to keep from rubbing. It also rubbed a bit on the front wheel well liner.
I lowered it and I haven't been able to trim enough yet to keep it from rubbing lol. But it will be the inner parts of the mudflap, lots of trimming of the back of the wheel well liner, and there's some sheet metal back there too that you might want to bend out of the way, it's easy to bend... and possibly trimming the front liner (or pulling it out of the way) and bumper cover.
Old Apr 22, 2012 | 04:13 PM
  #46
onesikeuro's Avatar
onesikeuro
sounds easy. I got this. lol
Old Apr 22, 2012 | 04:27 PM
  #47
dakotaff's Avatar
dakotaff
For my 285/50/20's, I had to trim the front splash guards and front wheel well liners. Any bigger and you'll have to remove a good amount more of each of those, and also probably have to trim (cut) some of the front bumper fascia (that could be ugly). Some guys have even had to remove the front splash guards completely to fit larger tires.
The SRT10 wheels have an offset of 25mm, so with the 285/50/20's, you'll be rubbing the sway bar and frame at full turn, but just slightly. My wheels have an offset of 19mm, so it's pushed out just a touch further than the SRT's, and I only get a very slight rub of the sway bar and frame on one side only.
Bottom line, you'll be much better off going with 285/50's with a leveling kit. On stock suspension, you can only fit 265/50/20.
This will give you an idea of the trimming involved.
The Green line is the part of the front splash guards that I had to remove.
The Yellow line is the part of the front wheel well liners (front & back part of the front wheel well liners) that I had to remove.
Nothing is visible unless you're really looking for it.
I'm not even sure if I removed any more since the picture, but I don't think so.
The rear tires will fit without any modifications.
Old Apr 22, 2012 | 04:35 PM
  #48
onesikeuro's Avatar
onesikeuro
Perfect. Ordering the wheels in 2 weeks. IM SIKED
Old Apr 22, 2012 | 04:54 PM
  #49
dakotaff's Avatar
dakotaff
Nice, pics or you're banned!
Old Apr 23, 2012 | 08:20 PM
  #50
onesikeuro's Avatar
onesikeuro
for sure
