HID wiring ?
Old Mar 6, 2010 | 12:37 AM
biker_ahoy's Avatar
biker_ahoy
Default HID wiring ?
I finally broke down and got my HID kit,
One question though, it apears I only plug into one of the stock headlight plugs off the truck, and the other is not used, does this sound right?
or should I be using both the headlight plugs?
Thanks.
Old Mar 6, 2010 | 12:47 AM
tdister's Avatar
tdister
Its sounds right. The connector to the original socket should just be to activate relays. Really low current and no need for using both.
Old Mar 6, 2010 | 01:06 AM
biker_ahoy's Avatar
biker_ahoy
Ok,
The Computers not going to think there is a bulb out with the one plug not in use is it?
Old Mar 6, 2010 | 01:10 AM
tdister's Avatar
tdister
Oh, it just might. I'm not the person to ask this. I forgot about that aspect.
Old Mar 6, 2010 | 08:45 PM
biker_ahoy's Avatar
biker_ahoy
Anyone know?
Old Mar 6, 2010 | 11:19 PM
Altair's Avatar
Altair
Dak attack!
Could try hooking it up without mounting anything as a test run. Worst case you get a check engine light just unplug the battery for awhile to reset the computer and contact the kit seller about it.
Old Mar 7, 2010 | 01:56 AM
BLUEKOTA985's Avatar
BLUEKOTA985
I have the hi/low beam kit...it hooks up the same way. My blown bulb light comes on only because I have a full led conversion throughout my whole truck for me to get rid of it. I would have to put relays on the turn signals to prevent them from hyper flashing and the light being on. Other than that you should be fine.
T
Old Mar 8, 2010 | 02:33 AM
biker_ahoy's Avatar
biker_ahoy
I pulled a head light this afternoon, and unpluged it, truck didn't give me any bulb out warnings, so I'm good to go. Now to figure out where to mount every thing and get it all installed.
Old Mar 8, 2010 | 10:29 AM
Moneyman19's Avatar
Moneyman19
you guys have a blown bulb thing? werid... ive had two go and nothing ever poped up.. i do have the SLT edition.
Old Mar 8, 2010 | 12:42 PM
biker_ahoy's Avatar
biker_ahoy
for the running lights / Tail lights Yes. / for the headlights No.
